which adhesive for cork?
Home Forums Hints And Tips for model engineers which adhesive for cork?
  • #30376
    Ian Welford
      @ianwelford58739
      Ian Welford
        @ianwelford58739
        Having been asked to make a "flute tuner", or rather repair a borken one by a friend. I needed to attach a cork plug to one end of it. The tuner is ( I suspect) rosewood and about 40 years old! I used "mopane" from Zimbabwe as the grain match is good.
        Then, being masochistic, decided to make a duplicate in African Blackwood. All fine until came to attach the cork to it. In the end I;ve used Araldite ( slow setting as I know I can rely on it). The original looks like it may have a pin or stiff rod through it's centre to reinforce the cork.
        Anyone found any better adhesives for cork? Didn't want to use contact adhesive as It MUST be central on the base and it took quite a while to get the diameters right.
        Ian
        I will try and put photo's up tomorrow.
        #88621
        _Paul_
          @_paul_
          In my youth I used to re-line British motorcycle clutch friction plates with cork which I stuck on with Araldite (only the original version available then).
          Wonder if you can still get the thin sheets of cork? my old Kawasaki needs a new clutch and I dont fancy the £30-40 for a set of friction plates……
          Paul
          #88631
          John Haine
            @johnhaine32865
            Cork tile adhesive?
