WHERE ARE THE SHAPER USERS ?
Home Forums Manual machine tools WHERE ARE THE SHAPER USERS ?
Viewing 25 posts - 101 through 125 (of 299 total)
  • #258580
      There's this from Arc Euro, but it looks bit too robust:
      http://www.arceurotrade.co.uk/Catalogue/Workholding/Vee-Blocks-Angle-Plates/Tee-Slotted-Angle-Plate-65x5x45
      My idea is to weld a pair of webs onto the angle and fit a tenon. Typical Adept quality there's a 1/16 deep by 1/2" machined slot along the middle t-slot, the other two are left wholly as cast and are decidedly wonky!
      The drill table works, but does flex too much at least it let me get an idea of how it works and just how much space is needed.
      A simple stepper with a belt drive to the feed handle will be easier to set up than fixing a ratchet, just needs a debounced microswitch to operate it.
      bodge
        @bodge
        hello Neil
        That does look very close to the original Adept table, Bazyle's dimensions are about right, im trying to up lode some pics, might not be successful !
        …………..b
        #258618
        Ex contributor
          @mgnbuk
          Can you have "too robust" on a shaper ?
          Nigel B
          #258622
            Here you go, Neil …
            The Reference Scale is from IKEA's Ultra-Precision range, and should [just] suffice.
            More, in this Album **LINK**
            http://www.model-engineer.co.uk/albums/member_album.asp?a=42334
            bodge
              @bodge
              Nigel B
              #258626
                That's great thanks, I had deduced the presence of the tenon!
                Not far off the Arc angle plate, really. I wonder what a casting would cost.
                #258627
                Brian Wood
                  @brianwood45127
                  Michael,
                  ​For a moment there I thought IKEA had added to their product range and were now selling Tee slotted things to grace the house contents. After putting on my glasses I can see the graduations on the rule—how disappointing!
                  ​Brian
                  Edited By Brian Wood on 30/09/2016 18:20:24
                  #258628
                    Posted by Brian Wood on 30/09/2016 18:20:06:
                    laugh
                    Very useful items, those paper tape measures … Never leave IKEA without grabbing a few.
                      The heart quails at teh thought of an Ikea Angle plate… MDF held together by mazak cams?
                      N.
                      #258698
                      bodge
                        @bodge
                        Hi Neil
                        MDF would be ok for making a pattern for getting a casting made, this should reduce the cost as i understand it the cost of making the pattern is usually the most costly part of the process, if you made the cope & drag also out of MDF mazak catches could also be used.
                        The tee slots look like they are cast in situ then just cleaned up with minimal amount of machining……………….b
                        #258704
                        John P
                          @johnp77052
                          Hi Andrew,
                          I think that the information in the Gears and gear cutting book is just there to
                          make the point that there must be some clearance between meshed gears ,
                          just working that out on 20 DP size of gears using the 48 / 52 ratio gives a
                          backlash of 0.0063 inch ,i would have though that was too much.
                          Obviously the ideal situation would be to have the correct tooth profile ie
                          cut to the correct depth so that both gears mesh at pcd with the correct
                          backlash ,i doubt that could happen if the gears were cut with a ratio of
                          50 / 50.
                          The extract taken from a book that i have would seem to suggest what
                          you have said is correct to get some more backlash is to cut deeper ,the
                          photo of this is in the gears album.
                          I think the problem in some cases can be the lack of information ,the hobs
                          that i use are from Arc euro and have no information as to the infeed depth
                          only the setting angle for the helix.As i eventually found out the infeed is the
                          full depth of the cutter to the root in this way the correct tooth form is
                          generated,using these to make the internal cutter means that there is no
                          extra length to the cutting tooth to cut the clearance at the root of an internal
                          gear.
                          Many of the problems with internal gears seem to be connected to either
                          interference when cutting with a pinion type cutter where a part of the
                          tooth is trimmed during the radial infeed ,or where a fitted pinion contacts
                          the edge during engagement refered to as trochoidal interference .
                          In both these cases it seems this is related to the difference in the number
                          of teeth between the pinion and internal gear.As you have pointed out these
                          connections are related to PA ,addendum and DP.
                          The book i am refering to indicates a difference of 11 teeth between the
                          pinion and gear ,this seems to vary in some publications.
                          The 14 and 21 gears shown in one of the photos have only a 7 tooth
                          difference but still run together well without interference .i think this
                          is down to the modified form ,the gears can only be assembled
                          axially and for that reason the internal form was broached.
                          Getting back to the shaper part of this thread i am in the process of making
                          a fabricated shaper ,there are some photo's in my albums ,at present the
                          project has stalled but when done will have some stepper motors fitted ,like
                          all of the rest of my cnc machines it runs on Compucut,Richard Bartlett was
                          kind enough to write a special file to be used on this machine which sets
                          the ratio to control two rotary tables , one is a proper rotary table and the
                          other is a cutting head which will fit on the ram,as part of the file the motors
                          only move on the rearward movement of the ram ,as long as the file runs the
                          two remain in syncronization. Using a similar 20 tooth cutter to the one
                          seen cutting the 36 tooth internal gear and using a ratio of 2 to1 equals
                          40 teeth on the rotary table ,using a ratio of 6.35 equals 127 .One could
                          see how useful this could be as every tooth number can be generated
                          from about 32 (internal) upwards to the physical limit of the machine.
                          It only leaves to problem on producing the cutter ,here again the shaper
                          comes to the rescue as the machine that i am building will have stepper
                          motors on the table and the column ,using the table traverse and the rotary
                          table it becomes possible to traverse and rotate a blank in time to generate
                          an involute form cutter just using a single point tool ,although the process
                          would not be quick using a pre-gashed blank would be a sensible option.
                          I see from an earlier posting the price of some internal cutters can be
                          £1200 ,i think for most shed men using about 12 pence worth of silver
                          steel to make a cutter could be an attractive proposition.
                          It probably seem a lot of work to produce a machine to cut these gear
                          forms but shapers it seems have many other uses as well as to holding
                          down a piece of floor.
                          Gordon A
                            @gordona
                            Neil,
                            I like your idea of a stepper motor to drive the carriage feed on the Adept 2 shaper. Instead of a de-bounced microswitch, have you considered an inductive proximity sensor to initiate the carriage advance? They appear quite cheap and plentiful on that popular online auction site, I understand that some or all have de-bounce circuitry built in.
                            Maybe mount one on a sliding bracket on the same axis as the shaper ram so that the position at which the carriage advances can be set to match the stroke.
                            I have been toying with how to add self act to my machine for quite some time, this could be a good "ancient and modern" solution.
                            Are there any more owners of this basic machine out there who have modified theirs?
                            Gordon.
                            #394786
                            RICHARD GREEN 2
                              @richardgreen2
                              BUMP
                              #394795
                              Joseph Noci 1
                                @josephnoci1
                                Bump?? – takes an Everest size bump to go back that far.
                                But, in keeping with the sentiment…
                                Not an Adept, just a little larger..
                                Joe
                                #394803
                                Andy Carruthers
                                  @andycarruthers33275
                                  #394805
                                  Mick Henshall
                                    @mickhenshall99321
                                    And another one
                                    Mick 🇬🇧
                                    #394810
                                    RICHARD GREEN 2
                                      @richardgreen2
                                      I picked up this Invicta 6 MR , 24 inch stroke shaper last year.
                                      #394817
                                      Colin Heseltine
                                        @colinheseltine48622
                                        My little Corbetts XL 7" Bench Mounted shaper. Picture taken just after reassembled but before it made it to the bench. Was stripped down, cleaned, painted inside and out, then reassembled with new motor and motor mounting plate.
                                        Colin
                                        #394818
                                        RICHARD GREEN 2
                                          @richardgreen2
                                          Nice job Colin, how old do you think the "Corbett" shaper is ?, it looks a useful machine.
                                          #394821
                                          Colin Heseltine
                                            Richard,
                                            According to lathes.co.uk they were made between 1953 and 1958. Its a nice little machine, but I still need to sort out a low profile vice and some tooling.
                                            Colin
                                            #394824
                                            Trevor Crossman 1
                                              @trevorcrossman1
                                              Posted by RICHARD GREEN 2 on 05/02/2019 15:19:34:
                                              I guess that when it comes to shapers, size does matter !
                                              That Invicta 6 will shift a lot more metal than my little 'ole' Boxford
                                              #394827
                                              Mark Rand
                                                @markrand96270
                                                Joining in the old thread resurrection. Before I got a bandsaw, the 10" Royal shaper did a fair bit of work as a power hacksaw:-
                                                #394833
                                                RICHARD GREEN 2
                                                  @richardgreen2
                                                  Here are some pictures of my Edgwick 20" shaper, machining some parts of a Stuart 6a compound marine engine that I'm building.
                                                  #394849
                                                    Interesting, thanks chiefly to this thread MEW has featured a lot more about shapers in the last 12 months. Issue 278 will see Joe Noci's computerised Alba Shaper as the cover story, hopefully of wider interest than just to shaper fans.
                                                    (Thinking of getting a bumper sticker "Real Men have Shapers" or "My other Mill is a Shaper&quot
                                                    #394875
                                                    Piotr
                                                      @piotr
                                                      One more shaper user checking in! I got a Swedish made Värnamo Prema 02 Shaper. It does a really good job cleaning scrap metal which would either take forever on my bench mill and/or ruin my end mills.
                                                      Prema 02 Shaper
