I have a Boxford 7" shaper, one with the 'rare' [according to Lathes.co.uk] rotating table.
I will be the first to admit I don't use it much, but then I don't have much call for milling type work. A shaper can cope with the work that the milling head of my Warco WMT300 can't – such as flats on a circular steel bar. The milling head on the Warco isn't stiff enough to do the flats and flexes as the end mill tries to ride up the curvature of the bar. This in turn mashes the end mill. The shaper, on the other hand, does the job perfectly.
Due to the low level of use for my shaper, I keep it on a castored trolley made from 2×4" pallet timbers and store it out of the way when not in use. As the ram moves back & forth there is a tendency for the trolley to rock back & forth an inch or so. However, as the drive belt is quite ossified, I cannot run it at any speed other than 'slowest possible' with the lightest of feeds, and the movement of the trolley stays no more than 1".
The real thing about a shaper is just how fascinating it is to watch. There is extraneous movement every which way, and I always attend on the machine even though it goes so slowly I can usually leave it for 10-15 minutes to slowly progress through a cut. I am convinced Heath Robinson had a significant hand in the original concept..
One thing I have found the hard way is that carbide insert lathe tools are no good – The reverse swing loosens the screw and the tip moves all over the place, wrecking the finish.
Richard.
Edited By richardandtracy on 26/09/2016 09:03:58
