WHERE ARE THE SHAPER USERS ?
Home Forums Manual machine tools WHERE ARE THE SHAPER USERS ?
Viewing 25 posts - 26 through 50 (of 299 total)
  • #256244
    Phil Whitley
      @philwhitley94135
      Heres mine, which is an Alba 1A and has just come out of it's hiding place for an oil up in order to cut an internal keyway for the little red tractor in the background. Why did I buy it? It was a good price, and I have never forgiven myself for turning down an Alba No 2 (maybe3) from a local school because at that time I had nowhere to put it. I did buy a HarrisonH mill and a Raglan V mill though, but the poor old Alba, went for scrap………………..I still have sleepless nights
      Phil
      RICHARD GREEN 2
        @richardgreen2
        Nice paint job Rik, was it sprayed or brushed ?
        #256260
        Rik Shaw
          @rikshaw
          Thanks Richard – it was brushed. Apart from the "dulux refurb" and a bare metal buff up I did not have to do to much else as there was / is little evidence of wear – amazing given the age of the machine (1959).
          Rik
          #256277
          Muzzer
            @muzzer
            Posted by Ajohnw on 16/09/2016 14:16:01:
            They can be used to make dovetail slides by attaching rope come string to lift the tool on the return stroke. Getting it wrong can make a bit of a mess.
            Alternatively you can just angle the clapper / toolholder to the correct angle from the vertical – that's what they are designed for. What an embarrassing mistake to make – did he / you get a good talking to?
            http://neme-s.org/Shaper%20Books/shaper_book_page.htm
            Edited By Muzzer on 16/09/2016 21:26:32
            Edited By Muzzer on 16/09/2016 21:27:24
            #256283
            RICHARD GREEN 2
              @richardgreen2
              Here's a picture of a 30" Elliott I used to use a few years ago, cutting dovetails in a 9" cube of EN9, no problems at all,
              #256294
              John Olsen
                @johnolsen79199
                I'm not sure that there are too many "must have" reasons for a shaper, since there will always be other ways of doing the job. However they are hard to beat for producing a flat surface with a finish approaching that of a surface grinder. They are probably more use for the guys building stationary and marine steam engines than for the locomotive guys, and also of course they are good for making angle plates and other parts for machine tools. You can also do some interesting things by mounting the job between centres on the shaper table.
                Dovetails are fun to do, and one advantage of the shaper is that you don't need to find a cutter to match an existing dovetail. I've needed to make dovetails with 55 degree and 60 degree angles. The same tooling will do for both. You can also do T slots, again without actually buying any special tooling, although you will need to braze some bits of high speed steel onto suitable shanks.
                I have three shapers myself, a 7 inch Amco, a 10 inch Alba 1A, and an 18 inch Alba. Obviously I don't really need that many but they are nice to have. Actually I used to have four, I had a 14 inch Alba as well.
                I've never heard of a shaper knocking its table right off, although a shaper crash can do a bit of damage. My Amco has had a repair done to the slotted arm which has been brazed back together, so sometime before I acquired it something noisy has happened. My 18 inch Alba had a piece missing from the dovetail of the downfeed when I got it, so it looks like that has been rammed into a job or the vice at some point. I was able to repair it by machining the broken faces square screwing on a block, then machining it to match the existing dovetail. (Using one of my other shapers!)
                Ady1
                  @ady1
                  It was one of the biggies, a 36" cincinnatti or a hydraulic rockwell kinda thing, some guys chatting on a US based site. They still seem to be pretty popular in the USA and have a good fanbase, I used to be a bit obsessed with shapers and read everything and anything I could find.
                  #256332
                  mark mc
                    @markmc72333
                    There is one thing a shaper can do a mill can't and that's cut it's own table. Here's mine, I love watching this thing
                    #256339
                    sparky mike
                      @sparkymike
                      Shapers have always frightened the life out of me !!
                      They must have originated in Victorian times and maybe they were used to shape a lot of the castings on traction engines and locomotives ? Don't think I would have the courage to operate one.
                      Mike.
                      #256353
                      Ady1
                        @ady1
                        They are great for doing rough and pitted surfaces, and the final result is as close to perfectly flat as any machine can achieve, so shapers/planers would have been a Victorian essential in any machine shop
                        #256354
                        mick
                          @mick65121
                          No workshop is too small for a shaper, mine is almost a hundred years old and still machines dead flat and parallel and builds up the right arm muscles as well! p 004.jpg
                          #256372
                          Clive Hartland
                            @clivehartland94829
                            Dangerous, I used one at 13 years of age at Tech. school. i made a woodworking vice and also cut a 1" square thread on a lathe driven by overhead shafting.
                            #256389
                            Ajohnw
                              @ajohnw51620
                              I suspect when buying a shaper and sometime other machines it would be worth checking any shear pins that are fitted.It's not all that unusual to find that they have been replaced with welding rod that has a much higher UTS than annealed brass.
                              As surprising as it might sound the chips off them can be pretty hot and can fly around so some sort of catch plate to intercept them if that is happening isn't a bad idea – and don't as I have seen on some youtube video's look along the work at eye level while moving the table to position for the first cut with the ram going.
                              I tried to find a video of one doing some really hard work. I think one guy did but along work with the jaws very wide open and he reckoned that the camera had run out of memory. I wonder if the work shot out or etc. He did have one interesting idea though to set speed – just fast enough for the chips to go very pale straw as they settle on the table.
                              I think they went out of use in larger companies pretty rapidly post WWII. Along with some other toolmaking aspects. Even high precision turning to a great extent.
                              daveb
                                @daveb17630
                                Mine was made in 1972 by Karl Anderle of Steyr, Austria. Model URK56, It has a built in dividing attachment and the table is height controlled by a hydraulic tracer. It can do copy profiling by means of a template. Was originally designed to produce punches and dies. Mine was used to make graphite tooling for spark erosion machines. Obsolete now due to CNC, very few appear to have survived. Nice toy though! Camera batteries flat, I will add photos to my album in a day or two.
                                colin hawes
                                  @colinhawes85982
                                  Different machines have different advantages, I use my 10" Elliot a lot. It is able to do wide flat surfaces much more easily than my small vertical mill and uses far cheaper tools that can be sharpened on a bench grinder. One job it did easily was to thin down several pieces of a broken Landrover leaf spring for a model using a HSS toolbit. My milling cutters didn't like that job at all. The shaper is ideal for surfacing tough, rough or rusty pieces of metal from my outdoor scrap heap. The shaper will cut long narrow slots exactly to the tool width with no variation at all and gear teeth close to a shoulder but on the other hand it is not really the best machine for boring holes so I don't understand why some folks want to compare it with the mill. They are quite different. Long live the shaper AND the mill.
                                  Colin
                                  #256554
                                  John Olsen
                                    @johnolsen79199
                                    The pale straw idea is about right for high speed steel tooling. You can use carbide tooling too, in which case having the chips come off blue and smoking is perfectly acceptable. I use some uncoated carbide tips, brazed onto key steel shanks. They are the sort with no hole and no top rake, eg a flat triangle shape. I sharpen them with a diamond wheel. I don't know what the grade of carbide is since they were being given away at the club. The guy who donated them said they had been trying them at work for turning and found them useless, but they are fine on the shaper.
                                    I have had a chip fly out and land in the little hollow at the bottom of my neck, not too much fun! The 18 inch Alba can take a quarter of an inch off cast iron in a single pass with ease.
                                    Shapers should not be compared with a vertical mill, the real comparison is with a horizontal mill. The horizontal mill can give a similar finish, but the cutters to do so are much more expensive. My Alba can do a flat face 18 inches wide with a single very cheap tool…the stack of cutters for a horizontal mill to do that would be much more expensive to buy and much trickier to get sharpened. The horizontal mill is of course much faster, and given a suitable set of cutters, can mass produce jobs with slots, chamfers and so on in one pass, a lot faster than a shaper would. The cost of the cutters matters a lot less when they are spread over many jobs. So for mass production there is no question, and industry has gone for milling machines. For an amateur, the economics are very different, and there is much to be said for a shaper.
                                    Are they dangerous? Well, all machine tools are dangerous to some degree, and I think I fear the woodworking tools in my workshop the most. The danger with shapers is I think partly that the ram seems to be moving at a leisurely pace, and guys are tempted to do things like wipe the loose chips off the job with a spare hand. Do not do this…if you must, use a brush with a long handle. You should usually be working from beside the machine so are not too much in the line of fire of anything that comes loose.
                                    thaiguzzi
                                      @thaiguzzi
                                      Posted by John Stevenson on 16/09/2016 13:51:12:
                                      Hold a piece of floor down until a better machine comes along
                                      Not that old chestnut again John…
                                      #257038
                                      thaiguzzi
                                        @thaiguzzi
                                        # I have a '79 S200 Boxford (late metric version of the 8&quot. Use it all the time. Only 2 regrets,
                                        1. I prefer imperial dials but on a shaper it's no biggie.
                                        2. Wish i'd got a bigger one. Something like an Elliot or Alba 10".
                                        # Finish with a shear tool is something to marvel at. Even a great fly cut finish on a mill does not come close.
                                        # Important thing with any shaper is making sure it has a table front support. Some of the very early models inc Atlas and Alba, did not have this detail, and without it, you can't really take proper cuts, as the box table will deflect under load.
                                        # Some pics in one of my albums of my shaper working.
                                        #257052
                                        IanT
                                          @iant
                                          Another happy Shaper user here too!
                                          My Atlas 7B gets used mostly for cleaning up and sizing scrap block before further operations. Like the power saw, it's one of the few machines I can leave to run on it's own for this kind of work and I can normally hear when it finishes the cut. I don't wander too far away but I can be doing something else in parallel – so speed isn't an issue. It will cut stuff that I wouldn't take anywhere near my milling kit and still give a good surface. With care I can produce a mirror like surface that I cannot achieve with anything else.
                                          My little hand shaper (Adept No2) gets used quite a lot for smaller work, where the manual operation isn't a problem and the results are better than I can do by hand (& eye) alone using a file or saw. Same way I can't file round (I use a lathe) – I can't file flat or saw (really) straight either. Eye sights not that good but once set-up I know the Adept will run true. So I think of it as my 'linear' lathe.
                                          That's it – once again – as we have this pop up every six month or so – and I'm still keeping mine!
                                          IanT
                                          #257057
                                          its-smee
                                            @its-smee
                                            Some time back I found a shaper on a well known website reasonably priced and I had to collect it from a shed in the Forest of Dean. It had been stored for a long time. Once all the rust and debri had been removed I cleaned it up and gave it a paint job. Light Grey was all I had at the time. the only thing lacking is a good solid metal table to hold it down. It also came with the original instruction book and spare parts manual. with a little research it turned out to be built around 1941 and still as good today as when it was built
                                            #257059
                                            its-smee
                                              @its-smee
                                              spare parts list but i doubt if they are available now
                                              #257062
                                              IanT
                                                @iant
                                                Very nice its-smee. Mine is an Acorntools (UK) version too – almost exactly the same as an Atlas 7B (which is why I call it that) but there are differences – the ram casting for instance. Atlas spares are sold/swopped in the States still but small parts can be simply made. I'm afraid mine isn't quite so pretty…..
                                                A few photos being worth many words – I will add these ones of my Adept No 2 cutting (modifying) laser-cut G3 wagon axle guards. There were a few to do and sawing by hand and probably cleaning up with a file after would not have been as quick or as neat in my view (although I'm sure others may disagree…) A thin, sharp parting tool and three four stokes later and all done.
                                                Adept Shaper 2 Adept Shaper 3
                                                #257063
                                                IanT
                                                  @iant
                                                  #257064
                                                  IanT
                                                    @iant
                                                    #257066
                                                    IanT
                                                      @iant
                                                      Sorry – multiple post – don't know how that happened.. ?
                                                      IanT
