I’ve just been glancing through some of the threads about clocks, and am reminded of the time when I was cutting the 96 tooth Great Wheel for John Stevens `Skeleton Clock with Lever Escapement’.
That was back in the early 70’s and I’m now 75, so please excuse any dithering in my notes.
With the second hand Myford ML7 which I bought around the early 60’s came a home-made dividing head with three plates. The ratio of the worm and wheel was the usual 40:1.
I was convinced that I had set up correctly so that the end result would display 96 teeth on a wheel measuring about 69mm diameter. This wheel engages with a lantern pinion so I took a chance and ground a fly cutter with a profile that might just pass as an involute.
I merrily progressed around the brass blank, and with manly pride, chose to check that the final move `into the first slot’ would prove that all was well. It wasn’t!
Before my eyes, the first tooth disappeared. Out came my Machinery’s Handbook from which I was to discover that with the plates I had, I could only divide to give 94 teeth.
Oh dear! or words of a similar meaning.
Then came the break-through. Of all the wheels in this particular clock, the number of teeth on the Great Wheel was not critical. Ninety four teeth was OK, so that’s where it rests.
Perhaps I’ll drop a Forum thread about my efforts at making the balance wheel.
I welcome any comments you chaps have to offer.
Sam
