What’s this for…no.7?
Home Forums Beginners questions What’s this for…no.7?
  • #786849
    beeza650
      @beeza650
      This is another shop made one. Sadly I washed the black paint off in my ultrasonic cleaner. Reverted to fairy liquid after that.
      It’s very robust and obviously I have no table with that v slot. What’s really weird is the knurled screw only pushes then clamp open. Wonder why.
      20250302_12385320250302_12374720250302_12382320250302_123841
      Bazyle
        @bazyle
        It is a holder for a dial test indicator for measuring things on a surface plate. The base would typically be 6 in long and about 2 in square, with a ground base.
        The screw is not opening the slot or hole per se; it is to make a fine position adjustment of the indicator that is held with a screw into the very end tread.
        look up “mercer indicator stand”.
        #786870
        Diogenes
          @diogenes
          Because it’s not a clamp, it’s a fine adjustment for the DTI/gauge that is likely to be hung off it..
          Bazyle’s fingers work faster
          #786878
          beeza650
            @beeza650
            Ahhhh. I see….thanks.
            #786882
            peak4
              @peak4
              Here you go, very much a lash-up, just to show one use, and the sort of base you’re seeking.
              S3020101_DxO-Facebook-s
              Here used to compare the 6″ stack of Jo blocks to what I believe is a depth micrometer calibration gauge, rescued from a defunct metrology repair company.
              I picked up a set of imperial & metric ones for very little money.
              Bill
              #786892
              beeza650
                @beeza650
                <p style=”text-align: center;”>Peeeerfect…I have just the v block. Going to check it firs this second</p>
                #786896
                Martin Kyte
                  @martinkyte99762
                  You are really missing a trick here. Should have saved this for a while and sold it to Neil Wyatt as an advent calendar puzzle for the December issue of the magazine.🥴
                  #786898
                  beeza650
                    @beeza650
                    17409286557586408796279414778085l
