James, your query indicates that of a beginner and as Tony says a tall order.
I can’t improve on Tony’s excellent overall description but I feel you may need a little more practical help.
As said all of these materials come in many forms and grades within their respective ‘subtitles’ but for the model engineer the knowledge of a few basics will help.
Cast iron is a relatively easy material to machine using conventional HSS tooling and or carbides. It is not normal to use coolant or cutting fluid when machining (Tapping excepted) Castings all have a skin which can be, though not always, much tougher than the material beneath. The hard spots mentioned can be a problem but reducing speed right down and or using carbide normally solves the problem. Continuous cast bar is ‘lovely’ stuff to machine, very homogenous and consistent quality. Once you have seen and machined a piece of cast iron you will have no difficulty in recognising it from then on !
Steels likely to be encountered at least to begin with are Mild steel either ‘Bright’ or ‘Black’.
Bright is cold drawn and has on flat bar – at first look – a nice smooth flat surface. This can be misleading when you need something actually ‘flat’. It’s big draw back from a machining point however is that because of it’s method of production it has high stresses ‘locked’ within itself and when a cut is taken these can release to a greater or lesser degree to produce some remarkable distortion. This can catch the unwary – it is best if possible to relieve the stresses by machining small amounts of each side gradually. This problem is not normally experience by turning round bar.
‘Black’ mild steel on the other hand is ‘hot rolled’, has varying surface ‘qualities’ and is not always square on its edges or very round but exhibits little, if any, movement after machining.
Both these materials are ideal for home machining and uses include linkages, con -rods structural parts etc. Preferably use coolant but can be machined dry but cutters will wear quickly
Leaded ‘freecutting’ mild steels EN1a etc are excellent to machine, a little softer than the above but much easier to produce a really good surface finish, lathe or mill. preferably coolant again.
The lower carbon steels likely to be encountered for instance EN3b EN8 are slightly tougher and used for similar parts likely to be subject to a little more stress.
Higher carbon steels as said can be heat treated to a hard enough state to use as a cutting tool or a surface much more resistant to wear than in it;s soft state. The two most likely to be encountered are Silver Steel – available in vast range of diameters -metric and imperial – and is easilly recognised by it’s ground bright silver finish. Gauge plate again in a vast range comes flat normally pre ground all round but some times has cut edges on the wider flats. Despite iits appearance it is not always truly square
Both are tougher to machine than mild steels. Use coolant or cutting fluid
Stainless I have less experience with but some are magnetic, not true stainless but considered ‘rustless steel’ Some stainless is notorious for work-hardening. It is most important to keep the tool sharp and cutting.
High Speed Steel is what you will use as a cutting tool. It is not normally available to the home user in its soft state and in most instances though not all comes ground either in square, rectangular or round form. It’s only ‘machinable’ by grinding and has the property of retaining its edge under higher heat build up than carbon tool steels.
‘Brasses or Bronzes’ of which ‘gunmetal’ is one covers an enomous range. Normally used for bearings or fittings (because of it’s propensity to resist corrosion) it is also used for castings of lighter stress components as well as major items such as cylinders. Machining again is relatively easy but requires absolutely sharp tools. A tool previously used on steel – if only once -will tend to ‘push’ the material as opposed to a clean cut.
Drillng of bronzes can be difficult because of work hardening. Again sharp tooling and small cuts – drilling in steps – will prevent workhardening.
As Tony says the subject is considerable, this scratches the surface and I’m ceratin their will be more o come for you – However I hope this goes a small way to expand that already posted.
The one factor to be borne in mind is that all these different materials have differing cutting speeds – that is the rate they rotate for their diameter on the lathe or the rate of the cutter on the mill – a subject in itself and catered for elsewhere on here as I recall
Kind Regards – Ramon
So far no one has commented on the costs involved. How long is a piece of string I guess. Tony sums it up well in that you need to know what you have. Buying it should guarantee that but not from a ‘car boot’ sale for instance. Then you do need that experience to be able to make a judgement.
The best of luck in your endeavours James
Edited By Ramon Wilson on 05/03/2010 11:34:05
Edited By Ramon Wilson on 05/03/2010 11:40:53
