What type of “plastic” rod machines best?
Home Forums Materials What type of “plastic” rod machines best?
Viewing 25 posts - 1 through 25 (of 34 total)
  • #29408
    Peter Bell
      @peterbell11509
      Peter Bell
        @peterbell11509
        I like to keep a a bit of “plastic” rod in the workshop, just in case. But I have now run out of stock and while looking around e-bay see that there is a vast choice. Just for odd jobs what is best/easiest to machine from natural nylon,  polypropylene etc?
        Peter
        #47200
          You could try Acetal, easier to work than nylon. Polypropylene is not as rigid.
          Jason
          #47205
          Martin W
            @martinw
            Peter
            It depends on its final use as, I expect you know, their mechanical properties are very varied plus some are more stable when exposed to things like sunlight (UV), heat, acids etc. As Jason says Acetal, often referred to as Delrin, machines very well but is slightly less stable than Nylon when exposed long term to sunlight. Nylon has a higher melting point than delrin but produces very stringy swarf when machined. For general purpose work I tend to use delrin/acetal as it takes a nice finish and taps well is relatively strong and fairly stable. Not only that it is readily available, quite cheap and doesn’t produce any nasties when being machined.
            In order to get a good finish on any of the plastics I found that it is really important to use VERY sharp tools. I use HSS that I have ground and then sharpened using a fine diamond hone, I don’t have a dedicated tool sharpening machine. This for me works very well, so its sharp tools and don’t let any heat build up when working the stuff.
            Hope this helps a bit
            Martin W
            Edited By Martin W on 09/01/2010 11:23:23
            #47206
            Peter Bell
              @peterbell11509
              Thanks for your help Martin and Jason.
              I take your points about sharp tools and sunlight. A bit of Delrin sounds ideal for what I need so I will order some offcuts pronto.
              Peter
              #47209
              Circlip
                @circlip
                ABS, Polystyrene, Polypropeline What’s the final use???
                  A lambo Countach is a great car, but absolute CR*P in the present weather conditions.
                   Regards  Ian.
                #47211
                Ian S C
                  @iansc
                  Hey Circlip saw someone on TV tonight In Sussex with a team of Huskies!!!!!Would an Igloo make a good workshop.Ian S C
                  #47214
                  mgj
                    @mgj
                    Trouble with Delrin is that its highly hydroscopic. Changes dimensions like a demon, so if its to fit in a bearing, or you want to make a bearing liner, make it good and slack, because it’ll tighten up on you first time it gets damp!
                    It does have an advantage – it’s cheap, and deservedly so.
                    #47216
                    Jeff Dayman
                      @jeffdayman43397
                      Delrin is NOT highly hygroscopic, it has very low water absorption.
                      However, after Delrin is machined, it does move around in size due to release of internal stresses and due to machining heat.
                      Sharp tools and air cooling are a good idea with Delrin machining.
                      Nylon is quite hygroscopic, perhaps this is what MGJ was thinking of.
                      Filled materials (ie glass fibre filled, mineral filled, etc) are more stable than unfilled plastics when machined.
                      Good luck, Jeff
                      #47217
                      Peter Bell
                        @peterbell11509
                        Great link that—did not realise there was so much variety of material.
                        Are the filled materials also as machinable?
                        Not going to use it for anything critical but found nylon certainly hydroscopic when trying to fit some large premachined bushes the other week, had to warm them up presumably to dry out before they were the right size!
                        Thanks  Peter
                        #47218
                        Circlip
                          @circlip
                          Some Nylons are less hygro than others and in some applications, the absorbed water content assists the basic material.
                            Filled materials tend to have a scruffy finish when machined from their extruded or cast shape.
                            And before we get there, some can be solvent welded AND solvent polished.
                            Regards  Ian.
                          #47219
                          mgj
                            @mgj
                            Well no doubt you have a different answer to the problem of tightening bearing blocks/gear change sleeves made of Delrin in racing cars in damp weather. (The plastic that is stable and non hydroscopic is of course PTFE – but it costs.)
                            Or perhaps a better explanation as to why APDS ammunition in the 120 tank gun spun off and was so inaccurate – many years ago. Actually it was tracked to the absobtion of atmospheric water in the Delrin driving bands during storage. On firing the friction turned the water to steam – assymmetrically – within the bands, so the band fractured in an uncontrolled manner, and  on shot exit the proj failed to fly true. (sometimes spectacularly so – wow was it fun to watch)
                            There are three reasonably good examples of the effect of water absorbtion by Delrin, giving rise to significant degradation in performance (not being able to turn a steering column  tends to be a touch awkward at speed) – Obviously your Delrin is different from everyone elses, and if so, I suggest people use it.
                            As Circlip says there are various engineering nylons, but Delrin is a specific trade name. Good stuff, and it has many good points, but dimensional stability in damp/wet conditions is not one of them – which is one reason why its not much used for seals etc in the Dairy industry.
                            Edited By meyrick griffith-jones on 09/01/2010 14:27:38
                            Edited By meyrick griffith-jones on 09/01/2010 14:28:55
                            #47220
                            Gordon W
                              @gordonw
                              Nylon absorbs water and swells, don’t know about Delrin.  Knowing the bush will swell by x amount, why not allow for that in the M/Cing? My steering bushes are plastic and not tight, don’t know what they are made of. Which is my point, how do we, as small scale buyers , have any real idea what we are getting ? I asked same question about HSS some time ago.
                              #47221
                              Martin W
                                @martinw
                                Peter
                                As I said in my initial post, this has been confirmed by other postings, it really depends on the final use. Yes delrin/acetal is hygroscopic and according to specs will absorb and or lose some water from or to the atmosphere. This will change its size slightly and if very close running tolerances are required then it could cause interference as Meyrick suggests.
                                Meyrick I would love to have seen he expressions peoples faces when the shells didn’t go as predicted. I can still remember the consternation caused when Rapier GtA missiles misbehaved in the early days, especially when there was an aircraft  in the air towing the target.
                                However as a general engineering plastic it is not too bad and as described in the specification doc has, and I quote, “The homo-polymer has higher mechanical strength, stiffness, hardness and creep resistance as well as a lower expansion rate and often presents a better wear resistance.” and before the big guns launch a broadside this is a direct extract from the product data sheet. So for general work requiring a reasonable finish where a small amount of dimensional instability can be tolerated it is fine. But it is horses for courses. You don’t use copper to make a lathe bed nor lead for a spring and the same applies to plastics!!
                                Yes filled plastics can be machined but then the problem arises as to the filler material. Some of these can be very abrasive and have the potential to blunt tools and deposit abrasive material on machinery. I know that when these materials are used in injection moulding equipment they wear the dies much quicker than unfilled plastics due to the abrasive nature of the filler.
                                As they say the choice is yours and whatever you choose have fun after all its just a hobby and should remain just that.
                                All the best to all
                                Martin W
                                Edited By Martin W on 09/01/2010 16:01:27
                                #47222
                                Jeff Dayman
                                  @jeffdayman43397
                                  Posted by meyrick griffith-jones on 09/01/2010 14:24:43:
                                  end of quote
                                   Delrin is NOT a nylon, it is Acetal resin, or PolyOxyMethylene polymer (POM).
                                  Nylons are in the PolyAmide family of polymer resins (PA).
                                  Perhaps you should stick to dispensing advice on items in your area of expertise, which clearly is not plastics. Just FYI I have no expertise on gun ammunition and can offer nothing about plastics on that topic.
                                  If you go onto http://www.dupont.com you can find a wealth of information on Delrin resins.
                                  http://www.boedeker.com has a wealth of information about plastics for machining and also grades reccommended for different applications.
                                  Cheers Jeff
                                  #47224
                                  Versaboss
                                    @versaboss
                                    Gents, I think you have forgotten another important type of plastic, PET (aka PETP or Mylar). As I have a little stock of that stuff and also of Delrin, I can say that they are quite similar in the mechanical properties and machinability. About PET it is said that its water absorption is very low.
                                    Maybe there is some confusion or mix-up here???
                                    Acetal resins (and Nylon too) are also available oil-impregnated for bearings.
                                    Greetings, Hansrudolf
                                    #47225
                                    Gone Away
                                      @goneaway
                                      Posted by meyrick griffith-jones on 09/01/2010 12:36:11:
                                      I don’t know where you got that from, Meyrick but anyone who’s worked in on spacecraft engineering would disagree with you. Nylon is extremely hygroscopic and as soon as it gets into a vacuum, it dumps the water and goes “twang”. It’s use has been banned by NASA since the 60’s
                                      Delrin is quite good in that respect and is often used instead of nylon on spacecraft. Delrin has its own Achilles’ Heel however in that it tends to build up internal stresses during machining which can later relieve themselves causing distortion. This is addressed in the aerospace industry by a stress relieving treatment prior to a final light machining. I’m retired now and it’s been a while and I don’t recall the exact details but I do remember that an oil bath is involved. I don’t know if the process could be adapted for home use.
                                      It’s possibly this effect that you have noticed with bearing liners although in my experience it’s generally parts that are very asymmetric that  show the worst effects.
                                      #47226
                                      mgj
                                        @mgj
                                        Jeff- I think we all know the difference between nylon and the various acetal co and homo polymers, and their engineering limitations and advantages. After all, some have been using them in critical applications for a little while.
                                        Nor even is the example resrticted to gun ammunition.  It was simply a case of what can happen when a supposedly non hydroscopic material fails to live up to the makers claims.
                                        Now if you’ll please stop being pedantic, and I apologise for using the term nylon loosely, we will all accept that you are absolutely right.
                                        Martin – as you can imagine, the excitement of actually firing main armament service sabot for the first time, and no one could hit a barn door, with these vastly expensive tungsten sub calibre proj’s winging all over the shop – quite literally a lot of this stuff was corkscrewing all over the sky.  (Suffield). The safety staff were getting a little exercised. It hadn’t affected us with the practise stuff because the turnover was much greater and the bands didn’t get the chance to absorb moisture.
                                        Going back awhile now but Delrin was seen as a bit of wonder material and du Pont  made all sorts of wonderful claims for it.  Indeed I remember the investigation because a lot of £ was riding on this, and how it was not possible for Delrin to behave like that etc etc. Well it did. The cure, rather like with my racing car bits, was to change the material.
                                        Gordon – you can allow for the change in dimension when machining – provided you are prepared for the bit to be slack in the dry and tight in the damp. Thats the problem. It swells, a little like wood does – though not to the same extent of course. To give an idea of the degree, I was just using standard H5 class reamers to provide clearance on stock sizes, and a Delrin block about 1″ x1.5″ would bind noticeably on that.
                                        #47227
                                        chris stephens
                                          @chrisstephens63393
                                          Hi Guys,
                                          (The following was written several posts ago, but i could not be bothered to change it in light of newer ones. Take from it whatever you want to)
                                          I think some of you are falling into the ” lets call all vacuum cleaners Hoover” trap., not all plastics are Nylon, but it is all to easy to call any thermoplastic “nylon” for ease.
                                          There are numerous versions of most commonly available plastics and it is a mistake to make generalisations. Take Nylon for instance, my catalogue from Watford Plastics lists three main types, type 6, type 66 and type12, then you can have with or without glass -filled, with or without MoS, you can even have oil impregnated. Oh and don’t forget the colour, which can have an effect on its application.
                                          If you follow Jeff’s suggestion and go to the Dupont site, there are again a vast number of different “Delrins”, all with slightly different properties and uses.
                                          Now for some sense(?), most of us will only have access to a limited number of plastics a few Nylons, maybe Delrin, HDPE, and of course Polycarbonate. I would suggest that most of us in the hobby end of the market would pick up a lump of plastic and use it for its electrical , bearing or “waterproof” properties, and not care too much about its ultimate mechanical properties. If we need a plastic for a particular use then we can look up which is the most appropriate for that job, but the original post was for a general purpose plastic, to have in store for the odd occasion when it is needed. I would think any old lump of Nylon or Delrin would do. In this case colour is most likely more important than properties!
                                          Now to back up ( well almost) what MGJ says, my catalogue says of Polyacetal (delrin). “Almost no moisture absorbtion” which I take to mean there is some, however slight. So stick that in your breech and fire it.    In the ultimate, extreme application that he had a use for Delrin, any slight inconsistency in moisture content would negate millions of pounds worth of fire control computer programming! His personal experience may well be different to ours but it is valid all the same. Most of us will never need to put any material to such punishing requirements or tolerances.
                                          chriStephens
                                          #47229
                                          Martin W
                                            @martinw
                                            Hi
                                            All of the above in response to a gentle enquiry about keeping a bit of plastic on the side!!  Wonderful and its what keeps forums interesting and informative. Great place to learn and get tips from various peoples experiences even if they vary due to the application materials are put to. I suppose I should have stated that lead is no good as spring at room temperature but might be fine if used in liquid nitrogen.
                                            Seriously there is a great deal of valuable information in these forums and many good folk always willing to help people like myself who, even at an advanced age well past retirement, are starting out to do what they dreamed of many years ago and that is making things out of metal that hiss, spin, look pretty (well to the beholder) with the great satisfaction of knowing that it was done to the best of ones ability and yes those two or more bits of metal are the same plus or minus the odd thou or two.
                                            So thanks to all who give their time and are prepared to share their wisdom and experience with numpties like me.
                                            Martin W
                                            #47230
                                            mgj
                                              @mgj
                                              Sid – does it not depend on what one is using it for?  If its a seal in a pipe, particularly for say hydraulic or gaseous stuff or somesuch for which it does not have an affinity, then probably it wouldn’t make much difference.(whether in space or not – no idea ).
                                              Hang it out in the wet on a racing suspension and you can get a problem – I don’t know enough about the presence of water in space, or the way materials are stored before use while on Terra Firma (nicely sealed in a poly bag?).  But that too can make a difference
                                              Equally store it in some magazine in Canada, and then use it as a driving band and you can get terrible problems from absorbtion in a very symmetrical circular driving band. And there is no if or but or argument about that. That’s what happened.
                                              The point is simple – it has, as Chris said, its uses, and its limitations, and it is as well to be aware of them.(Had a lot of trouble with Delrin locking bands on early Chieftain track tensioners BTW. Bit inclined to jam in wet conditions – until two of you just jumped on the long lever. Change to PTFE – bingo. OTOH Delrin in  oil baths – worked well) In other words it all depends on what one is going to do with it. .
                                              Would I make a steam engines piston rings out of Delrin – no (despite an apparent suitability). Would I try with say PTFE- yes (not that there is much point).  would i make a soft locking pad for a shaft out of it – certainly. Would I make a steam gland seal from it,- no.etc.
                                              I might also consider costs by the way. Off cuts of Delrin and many of the nylons are cheap as chips. Some of the plastics are almost hysterically expensive. PTFE for a start
                                              Edited By meyrick griffith-jones on 09/01/2010 19:36:33
                                              Edited By meyrick griffith-jones on 09/01/2010 19:37:25
                                              #47231
                                              Martin W
                                                @martinw
                                                Hi All
                                                While not strictly pertinent to the original post but more in line with Sid’s post it is surprising what metals absorb from the atmosphere. While working with high vacuum equipment we had to wait an awful long time before we could establish a decent vacuum. This was due to the steel the chamber was made from and the plumbing etc ‘out-gassing’. The metals, seals etc had absorbed gases from the atmosphere when at NTP and these slowly bled out as the vacuum was established. So it would appear that most materials, in one way or another, can absorb gases (includes water in molecular form) from the environment.
                                                Another useless bit of info but possibly interesting.
                                                Cheers
                                                Martin W
                                                #47232
                                                chris stephens
                                                  @chrisstephens63393
                                                  Hi Martin W,
                                                  “Another useless bit of info but possibly interesting”
                                                  Oh yes, indeed. Most people will only see things from their own perspective, but there are certain facts that only show up after very particular study. High vacuum or, say, Quantum physics might not have much relevance to the average Joe, but their effects are real!
                                                  Everybody should go through life with the philosophy that there is no limit to how much you can learn. You can never know when an odd titbit of knowledge will come in handy. Keep an open mind, always.
                                                  chris
                                                  #47235
                                                  Gone Away
                                                    @goneaway
                                                    Melrick – let me put it this way:
                                                    If a given part made from Delrin has a problem caused by water-absorption, I do not believe that replacing it with Nylon will solve the problem (far from it).
                                                    Conversely, if replacing Delrin with Nylon does solve the problem, then I don’t believe that water-absorption was the problem in the first place. More likely the problem was caused by the Delrin stress-relieving under the conditions of service (often temperature related but vibration and working stress can affect it too). This should be addressed by proper stress relieving treatment during manufacture.
                                                    Now, so that I don’t completely hijack the thread, I have had a lot of happy results in my shop with UHMW Polyethylene (often just called “UHMW”). I echo the sentiments about sharp tools (as with other plastics) although on the mill I’ve found that any regular end-mill gives good results, a nice finish and attractive parts. It has quite low friction which may be seen as an advantage or disadvantage depending on the application.
                                                    Locally, a number of tools stores sell inexpensive bags of UHMW as offcuts in various sections and colours, which avoids having to find a specialist plastics supplier.
                                                    Of course, the “wonder” material (in almost all properties) is Vespel (DuPont) but that’s pretty expensive stuff (or used to be – I haven’t checked in recent years). Probably about as stable as plastics come and easy machining to boot.
                                                    Edited By Sid Herbage on 10/01/2010 01:44:26
                                                    #47239
                                                    mgj
                                                      @mgj
                                                      Sid – you could well be right. I’m not a plastics man, and we didn’t cover them in any huge detail when I did my engineering degrees. I’m merely conversant with a number of applications where things have gone wrong with some of them.
                                                      The driving band business is of course not my opinion. Its the result of a comprehensive investigation by those who deal with these things. You don’t find, in the middle of the Cold War that your entire stock of anti tank ammunition (and that of many of your allies) is useless without getting a bit of twitch on about it. Especially when you thought you could store it for years.
                                                      As for the suspension/steering bit – I can only speak as I find. Damp day tight, dry day loose. Change to PTFE problem gone. Now thats just straight slabs of 5/8 plastic with a central hole and two clamp bolts. Each bit is very symmetrical.
                                                      I believe also without being certain that some tape recrders or record players had problems – broadcast quality ones like Ferrograph as were. Didn’t some of them suffer form wow because of problems with Delrin bearings absorbing water and changing dimension? This was in the tropics with high levels of humidity. Distant memory. Not important.
                                                      I note that Mr Rose with his very fine spherical bearings doesn’t use a Delrin coating – because dimensional stability and consistency of breakaway torque under a broad range of conditions is a very important factor in the high grade ones?
                                                      I note that in tanks on the very accurate and vastly expensive zero backlash  linkages connecting gun and sight mirrors they didn’t use Delrin sleeves. Because of the high moisture content of the atmosphere with 4 sweaty soldiers all breathing away.
                                                      Pople must take as they find. Its not a topic which interests me further.
                                                    Home Forums Materials Topics
