I found this motor in a bazar. There was no way to test it. But because it costs as much as two melons, I thought it was worth the risk. Since it still have the plastic cover over the shaft I even hoped that it might be unused. The problem is that it has no markings. All I can tell is that it is made by ABB and has a thermal protection switch.
By the size it should be in the range of 2.5 to 3kW. The windings inside are 0.6mm in diameter. I find this a little strange since I have a smaller motor, 1.4kW, that has 0.8mm windings. Without load it draws 1.45A. And it is very slow speed, maybe 750rpm. Inside it looks fine, there is no sign of overheating.
I wonder if is not designed to work for short periods of time, S2 class maybe? This would explain also the lack of a fan. And the thermal switch. I search a lot but I didn't find any information about it.
In the last picture that bearing looks fine or I should replace the grease? It doesn't cover all bearing. Maybe it is dried.
