Posted by duncan webster on 26/08/2016 19:59:32:
Posted by Neil Wyatt on 26/08/2016 19:43:25:
Posted by duncan webster on 26/08/2016 15:50:53:
The argument that building to scale in imperial is easier does not seem very strong to me.
It depends on the scale; my engineering models are 1:12 aside from 1:16 for 3.5" gauge and some of my boats.
so do you divide by 12 in your head in which case you'll get decimal inches? Or perhaps you convert feet and inches into decimal feet and just call it inches. I think not. You'll do it on a calculator, and finish up with decimal inches which no doubt you round to conventional 1/32 or 1/16. Just as easy to to it in metric.
Same argument for 1/16 scale, to convert say 11 ft 7 inches you have to work it out in inches (139), then divide by 16 to get 8.6875, then convert the 0.6875 to 11/16.
No I either do it a drawing program at 1:1 in feet and inches, then set the scale to whatever I need, typically with a precision of 32nds or 64ths. It's then easy to look at the drawing and drag any dimensions that don't round neatly to an appropriate guideline.
Or do it in my head 11 feet = 33/4 = 8 1/4 inches plus 7/16 = 8 11/16" – took as long to work out as to type, but I'm USED to thinking 1'-3/4".
In 1:12, 11 feet = 11 inches, 6 inches is 1/2" every inch is 1 1/3 sixteenths so you can say 11 inches 19/32 but over such a length 11 1/2" or 11 5/8" will probably be fine.
Now I could do that in metric but EVERY dimension needs to be tweaked or approximated, whereas with an imperial prototype most dimensions naturally fall on a convenient line. far more likely for the prototype measurement to be 11'6".
You may not be convinced, but this works for me although I would still recommend a new workshop is kitted out for metric.
