What to do with a sticky (as in toffee) portable radio
Home Forums The Tea Room What to do with a sticky (as in toffee) portable radio
Viewing 13 posts - 26 through 38 (of 38 total)
  • #615542
      I am reviving this thread to share another horror story:
      Several years ago, I bought a [good secondhand] Panasonic Lumix G1 camera body, which has been ‘safely stored’ in a zip-lock plastic bag, in a dark place.
      It is now so disgustingly tacky on all the matt surfaces that I will either need to strip it all back to shiny plastic, or just bin it.
      Moral of the story [I suspect] is that plasticisers leech out from the bag and degrade the matt finish.
      crying 2
      P.S. __  when I try a Google search [shopping] for “Propylene Carbonate” it returns mostly results for other compounds … Grrr
      Edited By Michael Gilligan on 30/09/2022 10:59:43
      Maurice Taylor
        @mauricetaylor82093
        Hi,
        Try Isopropyl Alcohol ,this removes soft touch plastic when that’s gone sticky ,leaving a shiny non sticky surface.
        Maurice
        #615548
        Fowlers Fury
          @fowlersfury
          Buy a small tin of black tyre paint from Al Frauds, apply after wiping with white spirit & allowing to dry.
          #615549
          david homer
            @davidhomer12226
            Try french calk or talc if you would like it to smell nice, just sprinkle some on and spread it out, it gets rid of the tackiness, worked on mine.
            David
            #615556
            Andy_C
              @andy_c
              Other than happy long term user try sticky stuff remover from Lakeland no connection. It works to remove stickers from books or more persistent sticky stuff without damaging but do try rest area first. It has a pleasant orange smell upon which it is based I believe. Also wd40 well renowned for also being effective.
              #615566
              Andrew Entwistle
                @andrewentwistle
                As Maurice also found, wiping with IPA has cleanly removed the sticky soft-touch layer from binoculars, a camera body and loudspeaker grille for me.
                Andrew.
                #615568
                  I have IPA and will probably try it …
                  I was only interested in “Propylene Carbonate” because it was recommended earlier.
                  old mart
                    @oldmart
                    Most of the trouble I have had is not with the hard plastic parts, but the soft rubbery handgrips deteriorating. Sponge can also turn into nasty sticke powder, linings of Mitutoyo and Moore & Wright instrument boxes come to mind, plus light sealing in film cameras.
                    Edited By old mart on 02/10/2022 19:28:17
                    #617227
                    RMA
                      @rma
                      IPA for me every time. I cleaned off 2 pairs of binoculars and a portable radio. The shiny plastic base isn't as nice as the original which unfortunately, doesn't last!
                      #617228
                        [UPDATE]
                        Yes, the IPA is working fine on the disgusting goo on the camera body.
                        I am in no rush, so am proceeding at “Conservation Department” speed angel
                        Dave Halford
                          @davehalford22513
                          Posted by old mart on 02/10/2022 19:27:16:
                          Also the foam liner of older crash helmets
                          #634598
                          Grindstone Cowboy
                            @grindstonecowboy
                            Just come across this conversation about sticky rubber parts on cameras. Not tried it yet, but will bear it in mind for the future.
                            The 303 Protectant can be found here
                            Rob
                            Links to https://www.nikoncafe.com/threads/rubber-grips-on-slrs-gone-sticky.269937/
                            Links to https://www.303products.co.uk/shop/303-automotive-protectant/
                            #634659
                            Ian Parkin
                              @ianparkin39383
                              some of the 303 protectant arrived and it seems to have worked well on the sticky grip oF A samsung camera..after 5 minutes its no longer sticky but only time will tell if it lasts a while
