What thinner for Trimite enamel?
Home Forums Materials What thinner for Trimite enamel?
  • #467183
    Grindstone Cowboy
      @grindstonecowboy
      Hi All
      Have unearthed a small, unopened tin of Myford touch-up paint (purchased from the Myford stall at the Harrogate show a number of years ago) and was wondering what thinners should be used with it. Or more importantly, as it's probably the correct consistency straight from the tin, what should I clean the brushes with after use? It states "Made by Trimite" on the label, but nothing to indicate appropriate solvents. I only have white spirits (turps substitute) on hand at the moment so would need to order anything else.
      Second question, on the alloy parts (changewheel and belt covers etc.), should I use an etch primer, red oxide primer, or can the enamel be successfully applied directly to wire-brushed, de-greased bare metal? When stripping them, it didn't look like there was any primer originally.
      Thanks,
      Rob
      Grindstone Cowboy
        @grindstonecowboy
        Myford touch-up paint from Trimite
        #467186
        Baz
          @baz89810
          I have a tin of the same paint and have used white spirit successfully to thin it and clean the brushes, regarding the alloy parts I would be inclined to use an etch primer, be careful which one though, if I recall correctly the Precision Paints etch primer is for brass and copper only, I would suggest Upol acid 8 available from Halfords and no doubt dozens of other places as well, if you want to spray or I think Hammeite do a speciality materials etch primer suitable for galvanised steel and ally.
          #467188
          Grindstone Cowboy
            @grindstonecowboy
            Thanks Baz
            I'll have to see how difficult it will be to get the etch primer at the moment, but the white spirit info is good news as I have that already.
            Rob
            #467195
            Baz
              @baz89810
              Yeah really weird times Rob, I am spraying some bits of loco at present and hoping I don’t run out of stuff. First time in my life I haven’t been able to nip down to the shops for something I am running low on.
              #467209
              KWIL
                @kwil
                I think it is their Q78 alkyde resin paint, have used it (Q78) on other things and although they have their own thinners (CT60), I used white spirit. For spraying up to 15% added.
                Mason Paints (late of Derby) also sold Myford Green paint and was a similar product.
                #467277
                Grindstone Cowboy
                  @grindstonecowboy
                  Thanks KWIL, it was mainly a question of cleaning – didn't want to use one of my good brushes, then find I couldn't get it off with white spirit yes
                Home Forums Materials Topics
