What thinner for Enamel paint.
Home Forums Materials What thinner for Enamel paint.
Viewing 15 posts - 1 through 15 (of 15 total)
  • #400040
    Brian Abbott
      @brianabbott67793
      Hello guys, need some advice.
      I have just bought and had delivered some enamel paint i am going to use to repaint a lathe stand, ordered some thinners at the same time but unforunatly the box must have been transported upside down and 75% of the thinners has leaked out the container.
      I am sure if i speak to the supplier they will sort something out but i am wanting to get on and don't want to wait, does anyone know an off the shelf alternative ?
      The paint is Paragon myford grey and the thinners is PT8
      Quick note, please don't read this as me having a go at the supplier, all was good and i know these things happen,
      Thanks all.
      Brian Abbott
        @brianabbott67793
        #400048
        Hopper
          @hopper
          I'm sure if you call Paragon they will tell you what type of thinners to use. Better to get it straight from the horse's mouth than general opinion on a forum. (Errors have been known to occur smiley )
          #400049
          pgk pgk
            @pgkpgk17461
            Paragons website states not to make the mistake of using other thinners.. specifically mentioning cellulose thinners. Their hazard sheets says PT8 is solvent Naphtha (petroleum) which I interpret as a subset of oil distillation. Naphtha isn't really specific and might include things like white spirit or turps substitute.
            Is it worth risking disappointment? If going to try it then obviously on some scrap first.
            #400051
            vintage engineer
              @vintageengineer
              Owatrol oil.
              #400059
              Chris Trice
                @christrice43267
                Any oil based enamel paint is usually thinned with White Spirit and also used to clean any brushes or spray gear.
                #400065
                Dave Smith 14
                  @davesmith14
                  I must admit I always spray enamels using cellulose thinners all my 4mm scale models have been done that way, also most of my railway club colleagues use the same technique. The thinners are only a carrier and evaporate to leave the paint. White sprit takes ages to flash off compared to cellulose.
                  Former Member
                    @formermember32069
                    #400094
                    RMA
                      @rma
                      That's really annoying but these things happen in carriage. I'm sure the supplier would replace and send quickly. I would wait and have the recommended product, you then minimise the risk of a bad job. I hate doing a job twice, but should the product fail for any reason, you'll have the support of the supplier because you used their materials. Good luck.
                      #400139
                      Mike Poole
                        @mikepoole82104
                        It appears to be white spirit, if you read paragons data sheet it gives an ec no. Which if you google it seems to come up with many references to white spirit, Barretine White Spirit being one of them, I don’t know how exactly the number defines a substance but as it’s a readily available material it could be worth a try. The downside is what the long term effect will be and whether a strip and repaint would be more annoying than getting the recommended stuffin a few days.
                        Edited By Mike Poole on 13/03/2019 12:01:00
                        #400141
                        Phil Whitley
                          @philwhitley94135
                          I thought that Mike, and white spirit may well work, but when I did my Colchester, I used Paragon paint, and the thinners smells similar to white spirit, but it is not identical, so while white spirit will probably work, it may affect the fininsh on the end result. Of course, you could get some coats on now, and do a final coat with the correct thinners when it arrives!
                          #400166
                          Nick Clarke 3
                            @nickclarke3
                            Posted by Barrie Lever on 13/03/2019 08:13:17:
                            The problem occurs if you apply cellulose (and other products with high VOC's) over well dried oil based paints such as enamal. The cellulose product will make the oil based product pickle and wrinkle.
                            Barrie
                            Natural oils are rarely used today, most enamels are synthetic.
                            When I worked in car paint it was (S) for synthetic and (C) for cellulose, or 'you can put (S)alt on (C)hips but not (C)hips on (S)alt'
                            The problem with cellulose (apart from what it does to the environment) is that you never know what is on there already.
                            Also if you are applying with a spraygun synthetic enamel is a very different technique to using cellulose. Runs are far more likely if you lay it on too heavy. Denibbing files (eg Machine Mart 040811450 or 040811449 for example) are your friends if it happens.
                            Edited By Nick Clarke 3 on 13/03/2019 14:56:32
                            #400175
                              Naptha is just a catch-all for the peteroleum distillates
                              PT8 probably means heavy naptha with averaging 8 carbon molecules per chain and could mean white spirit (typically with 7-12 carbon atoms).
                              Dave Halford
                                @davehalford22513
                                Synthetic Enamel for cars (legally only for machines now – as in lathes ) has a 'fast' thinner for spraying, still available from suppliers by the litre.
                                Surprised anyone will ship thinners by a non specialist carrier given the explosive nature if leaks occur.
                                #400224
                                Brian Abbott
                                  @brianabbott67793
                                  Thanks all for the reply's
                                  Ordered another container so at least i have to correct stuff.
                                  So far i am arguing over a minnie steering wheel with a bent handle. ( ordered last september, only just turned up )
                                  A minnie chimney saddle casting which is undersize.
                                  Now this..
                                  Must be having a run of bad luck..anyway..
                                  Edited By Brian Abbott on 13/03/2019 19:14:50
                                Home Forums Materials Topics
