What size chuck key?
Home Forums Workshop Tools and Tooling What size chuck key?
  • #16616
    Michael Wilde
      @michaelwilde12011
      1/4″ or 9/32″?
      Michael Wilde
        @michaelwilde12011
        I’ve just received a Bernard 4 jaw chuck that I bought on ebay, minus a chuck key. Its the ’34m’ 6″ model that has the words “made especially for the Myford Ml7 lathe.”
        I’ve used a piece of 1/4″ square bar to remove the jaws and give it a good clean, polish and lube. The square bar was quite a sloppy fit in the square hole and, on measuring it, found it to be 0.280″.
        This works out at 9/32″, is this the right size as it seems a bit of an ‘odd-ball’ size? or is the sloppy fit on the 1/4″ bar right?
        If anybody has this same chuck and wouldn’t mind giving their chuck key a quick measure I’d greatly appreciate it!
        I’m just trying to see if its worth buying one on ebay (1/4″) or making an ‘odd-ball’ size. Also, what to make it from? I can get off-cuts of quite tuff stuff from work (we call it durehete, used a lot in the power generation industry).
        Thanks in advance
        Edited By Michael Wilde on 09/02/2011 23:00:20
        #63859
        David Clark 13
          @davidclark13
          Hi There
          Buy a 5/16 or 3/8 in. one from Ebay, Five minutes on the grinder and you have a 9/32 one.
          regards David
          #63868
          Dave Tointon
            @davetointon92281
            Michael,
            I’d suggest you just turn one up!!! Must be one of the easiest turning jobs with a tee handle to suit. I made one out of mild steel and it has lasted years.
            Dave Tointon
            #63872
            NJH
              @njh
              Hi Mike
              I’ve just checked my Myford 6″ PB 4 jaw. The socket measures 7.74mm and the key. which is a loose fit in the socket, is 7mm AF. Both chuck and key are in as new condition.
              Norman
              #63884
              Gordon W
                @gordonw
                As mentioned before, a good source of square bar, in seemingly good quality, is old door locks, varies between 5/16″ and 8mm, can beefiled to suit if needed.
