I have acquired a Stuart Turner 500 boiler the boiler is in good condition but does have a small leak on the screw on the underside of the water gauge bottom fitting, Ive removed the screw and it's slightly corroded needs to be replaced as it's only 4/5 threads long. Does anyone have one of these boilers or know what the thread size could be it measures 0.158 so I would suggest it's 5/32 but I have a 5/32×40 ME taps and it's not that thread also I have 5/32 whit which looks to be close but not quite, the hex size is that of 3BA 0.282 It will not be a problem to tap it 3/16 but I would prefer to keep the size as is.
Looking at an old catalogue they only give the thread size of the connections to the boiler and glass size of 3/16" not what the end plugs or gland nuts are.
The odd Stuart fittings I have looked at have the blanking bolts all threaded 40 tpi by either 1/8 or 5/32 or 3/16 and the threads that fit to boiler bushes appear be 32tpi. I think I would double check your 0.158 measurement as it sounds very unlike Stuart !
An alternative idea might be to mill a 5 mm slot from one of the boundaries of the workpiece and then silver solder in a 5 mm thick piece of mild steel leaving a 5 m square hole, rather as George Thomas did to make a square hole for aligning number punches when making his staking tool,
Rod
Author
Please log in to reply to this topic. Registering is free and easy using the links on the menu at the top of this page.
