Regarding the blown 60 Watt lamp failing and then the main fuse blowing. Whilst this is not a common occurrence it does happen. As the element/filament fails it shorts across the pair of leads within the glass envelope forming a short circuit. The old type of wire mains fuse ages, not all premises have cartridge fuses even today. I will explain, the piece of wire, warms,expands, warms again, cools etc and gradually its cross connectional area reduces and then its fails, often at the most inconvenient time. When considering the size of cable for a workshop installation don't forget that you won't be using all machinery at the same time so total load is different to load in use. Diversity !
An interesting aside. 6 students rented a house, on arrival one switched on the hall light, it didn't work, another tried the living room it didn't work either. They tried them all of the lights and non worked, this was on a Saturday evening, so they used their phone to call the supply company. When the man arrive he checked the mains and all was well and at first he was a bit confused. The previous students had collected a lot of failed bulbs and fitted them to all lamp holders before departure. Total cost £75 .
