What *should* a Warco Super Major Milling Machine be able to accomplish?
Home Forums Beginners questions What *should* a Warco Super Major Milling Machine be able to accomplish?
Viewing 25 posts - 1 through 25 (of 75 total)
  • #472959
    Lee Jones 6
      @leejones6
      The current set-up is currently limited to ~1mm DOC before things get too loud and shaky.
      However, I'm planning to rectify that shortly: Stabilising a Milling Machine
      How hard should it be possible to push such a machine during various types of operations?
      Lee Jones 6
        @leejones6
        #472962
          DOC in what?
          How wide a cutter 3mm or 80mm facemill
          HSS or carbide?
          Cheap cutters or decent?
          #472973
          Lee Jones 6
            @leejones6
            In steel, with both 50mm carbide facemill and 10mm HSS endmill.
            CHEAP! 😀
            #472974
            Lee Jones 6
              @leejones6
              Posted by Lee Jones 6 on 19/05/2020 14:10:59:
              CHEAP! 😀
              Chinese facemill/inserts.
              #472976
              Dave Halford
                @davehalford22513
                Saw your other post Lee.
                What do the inserts look like?
                Have you checked the holder for runout? Some ER's are a bit grim.
                It sounds like something is slack enough to go knock, knock when you pull on it.
                The head should not shake independently from the column.
                My Centec 2A sits on a wheeled tool trolley and stays put so should yours.
                Edited By Dave Halford on 19/05/2020 14:17:36
                #472981
                  Go search the forum for facemill, I posted how bad a cheap 50mm facemill was, the reasons why and how I cured it. Also look at StevieGTR's recent threads where with the right inserts his facemills worked well, the cheap 50mm one did not but all in the same machine
                  Get some half decent milling cutters to, could do worse than these
                  Edited By JasonB on 19/05/2020 14:27:39
                  #473020
                  Martin Connelly
                    @martinconnelly55370
                    What is you definition of push? You can't just crank the handles as fast as possible and rev the tool as fast as possible.
                    Martin C
                    #473029
                    HOWARDT
                      @howardt
                      I have a SX2P with 3MT spindle and the original ball bearings about three and half years old. Running a 3MT 25mm diameter 2 tooth insert cutter with TPUN inserts at full speed, 2500 rpm, I can getaway with 2mm depth of cut on pretty much a near full width cut. Ways have to nipped up a bit otherwise the clatter becomes a bit much. It does cover the machine and bench in hot chips very quickly.
                      #473036
                      Lee Jones 6
                        @leejones6
                        This is what the inserts look like:
                        Not checked it for run-out, but the loud noise and vibrating happens with different cutters.
                        [Although, it has also just transpired that I have not been using my collet chuck properly!]
                        I'll do that Jason, thanks.
                        By push it, I purely mean DOC.
                        I don't have 2500RPM to play with. My machine tops out at 1600RPM.
                        #473038
                        Lee Jones 6
                          @leejones6
                          Posted by JasonB on 19/05/2020 14:25:21:
                          I just bought one of their roughers – arrived today.
                          Might give it a spin tonight (with my newly de-burred collet set!) and report back.
                          #473043
                            So here is the thread with my posts about one of the very cheap facemills and very cheap inserts.
                            Starts off with the vibration you mention shown by the light moving about, later posts shows head is a loose fit on arbor and later still what a difference better quality inserts make.
                            That was a couple of years ago, since then I have tried out the reasonably priced facemills and inserts from ARC, if you can get your hear running true then their inserts would be worth fitting.
                            With those things sorted I would say a good starting point would be 1mm DOC over 80% of it's width so 40mm wide passes at 750rpm in steel and 2000rpm on aluminium.
                            Stevie's finding with a similar very cheap one, other cutters work well with decent inserts
                            Edited By JasonB on 19/05/2020 17:29:30
                            #473052
                            Ron Laden
                              @ronladen17547
                              Posted by HOWARDT on 19/05/2020 16:43:27:
                              Thats a bit more adventurous than me Howard on my SX2P I run the 25mm 2 insert cutter at 1500 rpm with an APMT insert with a max cut of 0.5 mm on steel and 2500 rpm on alu with the APKT inserts max cut 1,5 mm but more often at 1.0 mm. I do adjust those settings to suit the width of cut but I am not brave enough to even consider 2.0 mm cuts in steel.
                              If you are getting away with it and the machine is happy then thats fine but I dont think my SX2 would be happy with it or at least I wouldnt expect it to be.
                              Edited By Ron Laden on 19/05/2020 17:52:45
                              #473068
                              Martin Connelly
                                A good starting speed and feed for the 50mm 4 insert cutter on steel is 450rpm and 225mm/minute.
                                A good starting point fort the 10mm HSS cutter is 800 rpm and 100 mm/min per flute, for a 4 flute that is 400mm/min, for a 3 flute 300mm/min.
                                Faster feed rates will cause a lot of vibration and noise. Slower feed rates will cause rubbing not cutting which also causes vibration and noise.
                                Do you have power feed or are you turning handles?
                                Martin C
                                Just spotted your other thread regarding stabilising the machine and I see it has a power feed unit. I would suggest finding out what the feed rate is for each setting of the speed control knob on the power feed and create a table to set it to known feed rates. That way you are also able to repeat setups that you know work or avoid ones that don't.
                                Edited By Martin Connelly on 19/05/2020 18:42:47
                                #473074
                                Clive Foster
                                  @clivefoster55965
                                  If my morphologically similar VFD controlled Chester machine (not the usual Lux) is anything to go by what you have is, for all practical purposes, a benchtop Bridgeport. When it comes to cuts rather than work envelope of course.
                                  Standing out in the open like that the practical limits are more to do with hot, or even cool, metal shower than fully exploiting the machine capabilities.
                                  When I got mine I already had a couple of the old style cardboard slide'n cutout window calculators that the cutter makers used to issue for, mostly, publicity purposes. I knocked about 1/3 rd off the figures for comfort and called it good.
                                  Since moving to a Bridgeport I've seen no reason to change the approach. Mit and flood coolant on board means I could easily but, frankly, the extra mess is rarely worth it.
                                  Do remember that, despite its impressive to ME eyes size and weight a Bridgeport is, in industrial machine tool terms, very much the 9 stone wimp wot gets sand kicked all over him.
                                  So taking around 2/3rd of this table values might be a reasonable starting point.
                                  Pasted Graphic.pdf
                                  But I find it much easier just to tweak what Mr Osbournes slide rule says.
                                  Somewhere on t'net there are some nice simple graphs of speed, feed and cutter sizes. I have one for lathe working laminated and pinned to the wall.
                                  #473083
                                  Ian McVickers
                                    @ianmcvickers56553
                                    I think your asking a lot of the machine if you want to push it more than 1mm DOC in steel. I had the GH universal and ended up stripping down the headstock and quill and fitting decent bearings to make it quieter. It used to rattle like hell before I did the refurb. Had to use bearing fit on some of the bearings because the recesses were oversize which really doesnt help. Refilled with H32 oil and it definitely improved things. Mine was sat on vibration feet and didnt jump about but was noisy.
                                    #473089
                                    old mart
                                      @oldmart
                                      I'm also of the opinion that if you want to cut a lot of metal, get something with some power.
                                        From what has transpired in lee's other posts I think his best option would be to reassess the vibration and inability to cut more than 1mm after a half decent milling cutter has been correctly held in a collet and again some half decent inserts fitted into a true running cheap facemill.
                                        #473102
                                        HOWARDT
                                          @howardt
                                          Remember those roughing cutters are HSS not carbide. I have them in 8 to 16mm, most awaiting a regrind. They shift metal but need to be kept cool and lubricated.
                                          #473114
                                          Lee Jones 6
                                            @leejones6
                                            Spent some time on the mill this evening.
                                            Firstly, I've put it on some interlocking foam matting, which has helped a lot.
                                            However the over-all noise reduction has highlighted what I think might be a bigger problem.
                                            Have a listen to the video below. The knocking coming from the gearbox is quite disconcerting.
                                            VIDEO
                                            Edited By Lee Jones 6 on 19/05/2020 21:50:20
                                            #473120
                                            Martin Connelly
                                              You have your 50mm cutter on H1 which is 600 rpm. This is about 1.5 times as fast as I would be running it. Try the next lower speed.  Your workpiece looks to be about 150mm wide. At 600rpm and going at the feed it looks like you have (about 150mm/min) you are probably alternating between cutting and rubbing. The burr being pushed ahead of the tool also looks like a lot of rubbing and not cutting is taking place. The same feed with 280rpm should cut on each tooth for the whole cut.
                                              Martin C
                                              Edited By Martin Connelly on 19/05/2020 22:03:39
                                              Edited By Martin Connelly on 19/05/2020 22:14:31
                                              #473123
                                              Lee Jones 6
                                                @leejones6
                                                Posted by Martin Connelly on 19/05/2020 22:00:54:
                                                Martin C
                                                Sounds like you are viewing the pre-view. You have to click on the video to play it.
                                                The next speed down is 280.
                                                #473126
                                                Martin Connelly
                                                  I have seen the whole video now and edited what I wrote.
                                                  Martin C
                                                  #473130
                                                  Lee Jones 6
                                                    @leejones6
                                                    Thanks Martin.
                                                    The part is actually half that (70mm), so I guess my feed is way too low.
                                                    I tried raising it and it just became louder and louder.
                                                    Do you think after a certain point, the noise will start to reduce?
                                                    #473132
                                                    Martin Connelly
                                                      You need to cut not rub. I was judging the width of the material by the fact it looked about 3 times as wide as the cutter. A 4 insert carbide cutter at 50mm diameter being used on steel should be running at about 450 rpm for the correct surface speed on steel. Slower is better than faster so you need to run at 280 rpm. At this rpm to have each tooth cut 0.125mm per rev you need to travel (feed) at 140mm/minute. Carbide inserts can be quite blunt compared to HSS so not feeding fast enough causes the insert to slide over the surface rather than digging in and cutting. The curling burr on the top of the cut is evidence of a lot of rubbing rather than cutting.
                                                      Find the power feed setting that moves the table 140mm in 1 minute and use that with 280 rpm and see if it all works more like you expect. The suggestion of new inserts of known quality may help as well.
                                                      Martin C
