Youch sounds nasty. Proceed with caution. The feedscrew is possibly made from relatively soft leaded steel for the sake of faster/cheaper mass production. I know the ends of both top and cross slide screws on my ML7 have been bent over the years by previous owner/butcher so they are not particularly stout. Certainly not high tensile or the like.
You may have to very carefully open up the hole with a tapping sized drill if it has been squeezed shut. Taper can be remachined in the lathe if you lock the cross slide in place using the gib screws or slide lock screws and machine using the top slide and carriage traverse. No idea what the angle would be.
