Dick, probably, I keep meaning to take it to my nephews place, but he's 40 K away, and I don't drive, but it will run on the electric stove with the element set at 1, and it really goes if you wind it up to 5, it just about jumps of the stove.
I actually made two fans, the other one is a Ringbom type motor, but if you know anything of these motors you will understand that it made too much noise(you might have heard of Tapper), it might not be so violent if it had lighter wooden blades, it would need 18" diameter, and maybe 4 or 5 blades, and some proper bearings, at the moment it has used skate board bearings, if they were any looser the balls would fall out.
I think I'v found a photo of an engine same / similar to yours in Model Engineer 18th Feb. 1977, "Stirling Engines, More Research and Development" by W. D. Urwick. I'm sure there are more pics, maybe a build article.
Ian S C
