Posted by Huub on 16/06/2022 22:13:13:
I started last year 3D printing and bought an Artillery genius. It came almost fully assembled and It took an hour to assemble and print the first test cube.
I started printing using PLA (the easiest filament) and after some time PETG. I am very happy with the results. I use it to print prototype parts (in stead of milling and turning) and it works like a dream.
I make the designs in FreeCad and use Prusa Slicer to make the files for the 3D printer.
I wished I started 3Dprinting years earlier, it had saved me a lot of time.
yes! I did too, the Ender 3 has a good support base but requires a lot of input from the user in terms of upgrading, great if you like to tinker.
the Artillery Genius is na different beast altogether, it comes in two parts that takes 5 minutes to assemble (4 bolts and a few connectors and you are ready to print, it has a direct extruder, colour touch screen, Volcano hotend and was available for around £180 (around half price if you look around). The Ender 3 does not even come close. There are lots of 3D printers around now to choose from, I go on best bang per buck principle.
I chose, after much deliberation, the Artillery Genius at a price of £340 over the Ender 3 at £280, but then stumbled across Banggood where price was £180 ish, sent from UK warehouse arrived in less than 48 hrs. Definitely a no brainer.
BUT, it is down to you and what you want out of it, you must make your own mind up depending on what you want out of your printer,
Just a point to note, Resin printers have been mentioned, without telling you the problems of mess and smell which can overide other considerations in a domestic environment.
Whichever printer you get, there will be a steep learing curve, despite what people may tell you, to get the best out of it.
Oh! and one final thing, you may have heard of automatic bed leveling, there is no such thing, it is nothing more than a software fudge – bed leveling is the ONE thing you have to get right (manually).
Edited By Howi on 17/06/2022 09:24:24
