What is it
What is it
Home Forums Workshop Tools and Tooling What is it
  • #166609
    Windy
      @windy30762
      I bought this at an auto jumble with the intention of making a small swing surface grinder for my shims etc.
      Another project that is on the back burner.
      It is very solid and wondered if it was part of a DTI assembly.
      A 6inch rule is in front for comparison.
      Is it what I thought or used for something else.
      Paul
      Windy
        @windy30762
        #166610
        David Clark 13
          @davidclark13
          It does look like a DTI Holder.
          Course thread for course adjustment. There is probably a fine thread under the clampfor fine adjustment.
          #166612
          Clive Hartland
            @clivehartland94829
            This reminds me of a Comparator I have seen. It is set up like a, 'Go' 'No Go' gauge.
            #166613
            Manofkent
              @manofkent
              It looks like the stand of a comparator. These were always pretty solidly built.
              #166620
              NJH
                @njh
                Hi David
                Nice to see that you are still " lurking"!
                Yep I think this is a comparator stand.
                Norman
                #166621
                  It could certainly make a good base for a T&C grinder.
                    Sorry Paul,
                    What I meant to type was 'that looks completely useless, would you like me to get rid of it for you?'
                    Oompa Lumpa
                      @oompalumpa34302
                      Posted by Neil Wyatt on 15/10/2014 17:18:02:
                      My very thoughts. It's the column I could use. I have found a piece of 2" bright round stock though. That and a leadscrew, all very interesting though and I feel a Build Thread coming on.
                      graham.
                      #166627
                      michael cole
                        @michaelcole91146
                        Yes, I have a comparator almost the same.
                        #166628
                        Robbo
                          @robbo
                          When I saw that column it reminded me of a Dore Westbury mill column that I have lurking about. Then I looked closer! Same principle though, a collar with a peg in it climbing up and down a slow thread.
                          Phil
                          #166638
                          D.A.Godley
                            @d-a-godley
                            I concur with those who consider it to be a comparator stand, I have a similar one which I use ,with some modification, to ensure alignment when presenting a tap to a drilled hole .
                            David.
