What is Blockquote? and why do we need it?
Home Forums New Forum Software questions, comments and Test Threads What is Blockquote? and why do we need it?
  • #705151
    Ian P
      @ianp
      Title says it all really.
      In case you have not tried it, This is Blockquote
      ‘Why’ also applies to the other text formatting facilities offered by this new forum software. Because this is a discussion forum I doubt many of us will be submitting complex documents that need numbered or bulleted lists, or right justified paragraphs for that matter.
      To be able to highlight the salient words in quoted text is a distant dream….
      The ability to be able to use the following in the editor would be like Christmas coming early for me,
      Choose fonts (even a limited range)
      Change font size
      Change font colour
      Underline would be better than strikethrough (but neither are that useful here)
      I only mention this now that the software team seem now to be tinkering with (to me ) minor details like the cookie and captcha icons, so they must be satisfied with their handiwork on the speed and login fixes. Maybe one day they will get round to removing the multiplicity/duplication of ‘forum’ and ‘subscribe’ buttons???
      Ian P
        Blockquote is simply a way of ‘quoting’ something [apparently anything!] without the need to reference the source.
        It is clearly more convenient than, for example, properly quoting a long post and then editing-out most of the content.
          ‘Why’ also applies to the other text formatting facilities …
          Here, for example I am quoting part of your post whilst correctly acknowledging that there was more content.
            … and here, I am not:
            #705173
            Ian P
              @ianp
              Yes, I see what it does. My point is that why would we need to use up about 10 lines of vertical space (shaded grey background) for one line of text. OK the wasted grey space might only be a small percentage if a massive paragraph was the block quote.
              The vertical bar offsetting for each quoted can be useful I admit but it does not need to be so tall in relation to the text.
              Ian P
              #705178
              File Handle
                @filehandle
                Ian
                If you don’t like the way the block quote tag displays simply code your own browser and you can display it how you like.
                Keith
                #705181
                Journeyman
                  @journeyman
                  The WordPress Editor
                  wpeditor
                  The editor provided is basically a sub-set of the WordPress old standard editor. I say old because it has been superseded by the new Block editor. One of the toolbars to the standard editor has been removed (or access denied)
                  The full editor allows Headings:
                  <h1 style=”padding-left: 80px;”>Heading 1</h1>
                  <h5 style=”padding-left: 80px;”>Heading 2</h5>
                  <p style=”padding-left: 80px;”>Heading 5</p>
                  etc Along with Colours as in Red, Blue, Green,  Special characters ΩβΞ  and a few other bits.
                  Whilst I can copy these and paste into the Forum edit box all the formatting is lost as is the HTML if I copy and paste that as above
                    here)
                    You have a long wait until xmas comes round again but never to late to start wishing
                    Probably not something that would get used much
                    Change font size
                    Again may only get used a small amount
                    Change font colour
                    Ditto
                    Underline would be better than strikethrough (but neither are that useful)
                    Underline is useful if no other highlight is available. Superscript for things like area and volume so the ² & ³ are raised would be good
                    Oh and looks like I have found a use for block quote too.
                    As the editing options only take up half the editor on a PC screen then there is room to add some more, probably better to have less on the phone option as to put them all there would take up 2 or 3 lines.
                    A bit more contrast to the quote background colour would not go amiss either
                    Lastly I would not say the cookie and login changes were minor issues, look and user friendlyness are low down the list.
                    Edited to show off Moderators Perks
                    #705205
                    Journeyman
                      @journeyman
                      It may have been mentioned elsewhere but you can get some extra formatting codes by pressing:-
                      Shift + Alt + H
                      <h2>You can get Headings</h2>
                      Underline text (which was mentioned)
                      but not all the commands are operable. And when you submit the text it disappears, oh well!!
                      Grindstone Cowboy
                        @grindstonecowboy
                        Just testing
                        This is underlined
                        This is bold
                        This is italics
                        Edit – ah, didn’t fully work as expected
                        #705234
                        peak4
                          @peak4
                          On Grindstone Cowboy Said:
                          Just testing
                          This is underlined
                          This is bold
                          This is italics
                          I tried that a while ago, but it doesn’t seem to have been noticed. Point 12B
                          or at least not provided (yet).
                          Like you, I was fooled when it worked in the edit/compose pane.
                          It does make it tricky to quote someone, whilst retaining the italicised highlighting in the original text; compare your original post to where I quoted you above.
                          Bold & Italic can be combined though from both the icons and Control B or I, it’s just U that doesn’t carry over.
                          Given that this is an engineering forum, it’s a shame we are also missing superscript and subscript from the formatting banner/ribbon.
                          Bill
                          #705477
                          File Handle
                            @filehandle
                            It is interesting to see what is happening behind the scenes if you use your browser or an editor to look at the source code behind the pages.
                            If you don’t like the way pages are displayed you can also use the setting in your browser to change how pages display. If you compare different browsers there are subtle differences in the way pages are displayed.
                            Test
                            <style>
                            sup {
                            vertical-align: super;
                            font-size: smaller;
                            </style>
                            <p>Normal <sup>super</sup></p>
                            <p>5<sup>3</sup>= 125.</p>
                            End of test
                            #705479
                            File Handle
                              @filehandle
                              I think that I tried to create superscript on a previous occasion with HTML, which didn’t work so thought CSS might, but no.
