I have a home made tool and cutter grinder (Think of an unholy alliance between a Worden, a Kennet, a Quorn, a bench grinder and my scrapbox). It gets used mostly for end mills, drills, slitting saws etc. mostly in HSS, but with very occasional tickle ups for carbide cutters
I would like to change over to the resin / diamond wheels mostly to save on the grit created by wheel dressing. I also see there are electroplated wheels with diamond impregnation at rather higher prices, are they worth the extra?
What grit # do folk use for tool grinding with diamond wheels?
Anything else I should know before taking the plunge?
Thanks in advance,
Martin
How about it’s a bad idea, don’t do it. Tool abuse!
Whilst Diamond sounds like a good bet because it’s much harder than HSS, and ‘common sense’ suggests it will abrade steel in short order, there’s a booby trap. There’s no such thing as common sense! Here, the non-obvious problem is that Carbon dissolves in hot steel, and grinding gets more than hot enough for this to happen. Diamonds are rapidly destroyed by grinding steel, about fifty times faster than normal if my memory is right.
HSS can be ground on diamond if the operator insists, but it’s better at wearing out diamond wheels than removing unwanted steel.
Ordinary wheels are best for grinding HSS because they’re cheap. CBN should grind HSS efficiently and need less redressing but it’s not cheap. How much trouble is it in a home-workshop to clean up grit after a dressing? I’d rather moan about it than pay for CBN!
Save diamonds for sharpening Carbide / Ceramic tooling, dressing wheels, and hand-honing steel blades. They’re really good at that.
