What grade diamond wheel for honing carbide?
Home Forums Workshop Tools and Tooling What grade diamond wheel for honing carbide?
  • #607363
    Grindstone Cowboy
      @grindstonecowboy
      I've been offered a 1200 grit diamond wheel, which I propose to use for honing carbide lathe tools by mounting it on a low-revving motor. But before I go to all that trouble, do you think 1200 grit is a suitable grade? I have a feeling it may possibly be too fine to be of much use.
      Thanks for any advice, or examples from someone who has actually done anything simlar.
      Rob
      Grindstone Cowboy
        @grindstonecowboy
        Is 1200 too fine?
        #607367
        Stuart
          @stuart18648
          1200 will be absolutely fine Rob. I normally start with 1000 then finish with 2000 and it doesn't take too long at all.
          When I'm feeling particularly indulgent I'll mount up an alumina wheel charged with 1um diamond for a mirror finish
          #607368
          Grindstone Cowboy
            @grindstonecowboy
            Thanks Stuart, I'll go ahead then yes
            Rob
            #607369
            bernard towers
              @bernardtowers37738
              Any particular reason you are going to use a low revving motor?. I run my 4 and 6 inch diamond wheels mat 3200 rpm. I would have thought that higher revs and light cuts were the order of the day for a fine finish.
              #607372
              Grindstone Cowboy
                @grindstonecowboy
                Hi Bernard
                I was taking ideas from this video by Stefan Gotteswinter – it would certainly simplify things to just go with a bench grinder. The wheel is the type with the diamond on the face, rather than around the periphery.
                Rob
                Links to https://www.youtube.com/watch?v=GOBtH4m2TYo
                #607380
                Neil Lickfold
                  @neillickfold44316
                  You can run the wheel wet in low rpm ranges and not make a mess. The water just takes away the carbide particles blocking the wheels surface. The low speed has the advantage of very low heat.
