Posted by Steve Skelton 1 on 06/07/2020 09:22:43:
I am assuming that 3D LAC is soluble in acetone – have you tried this to remove it from the bed?
Hi
I believe the solvent used in 3D LAC is Denatured alcohol ,
I use IPA [ The industrial version not the Malty Amber type !!
] to clean the heat bed surface.
Methylated spirits could also be used
To get a decent area of a model to adhere to the bed I have often use the "Brim" feature about 5 -20mm depending on the size of the object and how large a flat area it already has on the base.
The brim is easy to remove from the object and doesn't use much filament compared to a Raft, serves much the same task as " Mouse Ears" but you don't have to design it in.
The Brim feature is in Cura and Slic3r, I use Repetier Host on the PLA printer [Leapfrog Creatr] but the proprietary UpStudio doesn't have it for the ABS UpBox !
Steve
Edited By The Novice Engineer on 06/07/2020 12:08:30
Edited By The Novice Engineer on 06/07/2020 12:25:33
