What do you use for heat treatment?
Home Forums Workshop Tools and Tooling What do you use for heat treatment?
  • #575739
    jaCK Hobson
      @jackhobson50760
      Posted by Alan Wood 4 on 17/12/2021 20:57:41:
      ATP-641 Anti Scaling
      Reccomended. It doesn't like being frozen so beware keeping it in a cold workshop. Also good as a basis for the clay when hardening something like a japanese sword. Mainly because it 'sticks'. You probably won't find details of the mix that Japanese masters use – some combination of clay, sharpening stone slurry, charcoal etc… probably rat droppings in some. Bodging up your own is quite likely to result in something that falls off. I have had some success with fireclay.
      Edited By jaCK Hobson on 18/12/2021 11:33:24
      Clive B
        @cliveb55652
        ATP-641 doesn't "wet" the surface of the (clean) steel all that well and I've found that adding a little drop of iso-propyl alcohol or meths to it helps a lot and provides better, more even coverage. Works for me anyway, although it's not in any of the instructions. Obviously let it dry before placing in the kiln…..
        #575747
        noel shelley
          @noelshelley55608
          A simple point in the context of tempering DO NOT use engine oil, it will fume badly, cooking oil is better and a deep fat fryer will work. Good luck. Noel.
          #576719
          Mick Henshall
            @mickhenshall99321
            Still using paraffin blowlamp from the 1951 a Monitor,and a Berlyn 1965
            Mick
