Hi Guys,
Let me start by saying I am not advocating any particular measuring system, I am asking “what do we really mean by saying I work in (say) metric units”
It clearly does not mean that I use metric drills or milling cutters, because they are just tools, you don’t use a file and say you are using it it in metric.
It surely can’t just mean that I am using a metric scaled Mill or lathe, because those machines are used to make something to a size and as we know any particular size can be expressed in whatever units you like, physically it is the same. I am looking for a deeper meaning than this.
The only thing that I can think of that really makes a difference is the size of raw materials that we start with and then only because we might, say, have a single size collet that such stock will fit. We might also legitimately say we use Imp reamers because we need a hole to fit an IMP piece of ready made ground stock. This though is just a fact of standard sizes, rather than “I only work in IMP units”.
Another factor that might have some bearing on the matter is a set of plans that we wish to follow. Here again, other than using a few stock sizes that we can change to suit our measuring equipment, all dimensions that have to be cut to size can very easily be swapped, by simple use of charts or a calculator, from one system to the other. If we are not using plans but scaling a model from full size, then if we are using 1-12 as our ratio a particular system might seem to have the edge, but again any size can be defined in anyway you wish..
Might I suggest that what we mean by saying “I work in “X” measuring system” is that there are a few stock sizes that I use and they just happen to be measured in even numbers of mm’s or fractions (or decimals) of inches. If we are turning to a size it is only psychologically nice to turn to whole numbers. It feels nicer to turn to say an Inch rather than 25.4mm or turn to 25mm rather than 0.984″, because of the simple numbers involved, but the accuracy needed does not change at all.
I offer the above as a start for an intellectual discussion not a soap box for bigoted or biased dogma. I just want to know what people really mean by saying they use whichever units. I don’t suppose that even the most ardent fan of, say, metric would refuse to buy a piece of 1″ round stock because it was sold as IMP. In addition, I hope that we don’t, again, risk having to buy 6.35mmBSF bolts, because of someone else’s dogma.
Over to you., and please keep it friendly
chriStephens
