Hi, I've had these clamps since the 70's, the top and bottom set don't have any manufacturer on them, the two in the middle have "Futter London Limited" stamped on them, but I seem to have lost or mislaid the middle size one. While the top five are steel, the bottom set is an aluminium alloy. They were not very expensive but the quality shows that but they are useful at times and I use the little ones quite often, but never seem to have enough and the larger ones get in the way. So! I decided to make some little ones early last week and having found a short piece of rusty 25 X 6mm black flat bar and cleaned it up in some washing soda solution and a bit of elec-trickery from my car battery charger, I milled the edges flat and marked out for eight to be made and using my DRO on my mini mill, drilled and tapped eight holes about 10mm deep for M4 socket head set bolts.
When these were all done, the bar was then put in the vice with the flat sides and holes for making a gap were marked with a centre drill, again using the DRO to get them in the right place.
These were then drilled 7/16" on a drilling machine.
This was then mounted back in the vice with the tapped holes downward and with the first gap to be cut sticking out of the right hand side and with a couple of slitting saws ganged up, cut the gap.
Once cut the bar was taken out and the first clamp hacksawed off and the bar was put back in the milling machine vice for the next gap to be cut, but some wally put the wrong end facing the cutters, oh! that must have been myself
big mistake.
I left the mistake on so that I didn't do it again and just carried on cutting the next gap. After cutting two or three more I though to go and look for another shortish bit to make up eight, but found a bit of scrap off cut of angle iron and cut a piece out that would make two more.
I trimmed the new piece up as before and drilled and taped it as before, but did them opposite hands.
Then when I only had one more gap to cut, I wondered if I could save the one that I cut wrong and so turning to that scrap piece I trimmed a bit more off it and milled a couple of channels on each side, a quarter of the metal thickness deep.
I then slotted the bad end half the thickness in the middle position
These two fitted together very nicely and I drilled and pinned the two slotted sections and and after cutting the last good one off, I silver soldered the joints, this was then cleaned and trimmed and the gap cut.
Today I finished filing a small radius to the inside corners of all the clamps and put all the bolts in.
This is the one I silver soldered a repair and all the bolts had a slight dome filed on the end of their threads.
OK, they are not exactly show pieces, but they work and will do the jobs.
Regards Nick.
