What Did You Do Today 2021
Home Forums The Tea Room What Did You Do Today 2021
Viewing 25 posts - 101 through 125 (of 480 total)
  • #528413
    Nigel Graham 2
      @nigelgraham2
      I'd probably still be using my first portable 'phone – a Nokia I think – if damp on a very wet holiday hadn't destroyed the liquid-crystal display. I'd had it only about 12 years, and had replaced the battery a year or so before its demise.
      it was not one of those near-brick-size things but the next type on. Still slightly bulky, but lighter and easier to use than the so-called "smart"-'phone.
      I found a mail-order instrument-battery company, in this country too, and the repair was easy, though. I was surprised to find the battery was a set of AAA-size cells in shrink-sleeving.
      Now then… What Did I Do Today?
      A short little turning task for the Worden T&C Grinder, then another exploration of the Drummond shaper to find its elusive serial number. I've been advised to look where I'd not expected – on the slideways – so will do tomorrow. Oh today – it's already gone mid-night.
      Then used the BCA jig-borer for the first time in anger after spending several days making it a mounting for Myford chucks.
      I needed to put two spanner flats on a special nut, in mild-steel, 1" dia. Easy you might say, on a jig-borer… mill down one facet, rotate the lot 180º, mill the other facet, rotate and trim to finish as necessary. All lovely and symmetrical.
      No – I was distressed by a very large eccentricity I could not track down. My first thought was my mistake in swapping from the chuck in the lathe to one on the BCA, but even when I used the same chuck on both machines for a second nut I still had that huge run-out. I had to cut the facets individually, losing part of the rotary-table advantage.
      I did not throw the first nut away. When I measured it, I found it is actually useable, and will keep it as a spare. It is the cutter-locating part of the T&C Grinder's slitting-saw attachment.
      Oh what a battle though! I started just before my Inside Science tea-break finished (5pm), but by the time I could prepare to come indoors for tea, poor Brunnhilde was in her magic sleep up there on the mountain. Loge was setting the barrier ring of fire round her, while I was de-burring the nuts.
      So far I have not detected sufficient error in the mounting for 0.04" – forty thou! – run-out of the work-piece.
      Is the chuck leaning over, rotating the work on the surface of an imaginary cone? I fear this will not be easy to locate, let alone cure.
      It's a still fairly new, 4-inch 4-jaw self-centring TOS chuck with a remarkably deep body considering the spindle thread is outside, on a back-plate. I do wonder what these big heavy chucks do to a small lathe like my Myford 7. It would be more appropriate on the Harrison L5, whose own spindle nose is not much larger than the Myford's. However, before blaming the chuck I will test the adaptor assembly more thoroughly. A massive chuck screwed to a small adaptor held in a shallow recess by just M4 screws is not conducive to stability.
      ChrisH
        @chrish
        Not today but yesterday, I went an bought a replacement rechargeable hand torch, a fairly big one, to replace the same one that is now about 18months old and would not hold a charge and glowed only but dimly.
        Me being a hoarder, I took the old torch out to my shed to see what fancy new-fangled battery it had and to then see if I could buy a replacement anywhere.
        Stripped it out and found to me surprise that it had a little 4v, 2cell lead-acid battery, not one of the fancy new types I was expecting. And I found I could lift the little cover off, revealing the two little rubber caps over the cells, these came off and there was access to the cells. They seemed dry, not that you could see inside the hooles are so small. I have some little hyperdermic syringe bought in Italy a few years ago, but then couldn't find the battery top up water. But I did have a fulll tank of condensate from the dehymidifyer handy, so a little of that water was added to each cell and then the battery left on charge all night.
        So tonight I tested it and its back working just like a real one again. So now I have two!
        Chris
        #528667
        HOWARDT
          @howardt
          Finally received my Warco GH Universal a couple of weeks ago, but other than opening the box and a test run it remained on the pallet for a week. This week stripped off the motor and head, then found I needed a 12mm key to get the column off. I stripped it down so I could lift it onto a bench as the garage has limited height and didn’t want to buy a lifting device unless I really needed to and hire costs are nearly the same as buying. Any way, got a hex key set and then yesterday and today managed to get it all back together on the bench. The head is by far the heaviest part, probably about 100kg, but with a bit of Egyptian ingenuity managed to get it up to height without damaging it or me. Now to spend a couple of hours tomorrow trimming it all in. At least now when I can get a base it will be a simple case of sliding it from the bench onto the base. Next job is a DRO and maybe powered head lift.
          #528671
          PatJ
            @patj87806
            Working on 3D models for the steam ship Mississpppi side lever engine, with hopes of one day casting one.
            Proposed beam is 24" long.
            Go big or go home as they say.
            Edited By PatJ on 19/02/2021 21:43:33
            #528689
            Roger Best
              @rogerbest89007
              I finally got out into the workshop!
              I have been poorly recently and also focused on stuff in the house. I was made more determined by the stress of having both my mother and wife being of concern.
              My mum is almost 80 and appears to have caught Covid during a hospital visit for chemotherapy, during which she also had an adverse reaction to the treatment that needed emergency treatment. You couldn't write it.
              An afternoon of carpentry, has done me the world of good. I am building a fume cupboard, that will allow me to paint, weld, solder and steam when the weather is poor. Now the frame is up it looks about the right size. Lord knows where the sashes are coming from. The fan is sorted, not a proper EX-rated one but it should be OK if I keep the solvents to a minimum. Filters are easy – kitchen hood carbon filters are great.
              A bit more tomorrow and I will be able to fit the vice I have been renovating and maybe even take the surface plate from out of under the sideboard and out into the workshop. The big bonus will be stocking up the drawers with all the tools from the house that I can never find when I want them.
              #528719
              Nigel Graham 2
                @nigelgraham2
                Yesterday I was very disappointed by being unable to cut two spanner-flats on circular nuts in the intended way, on a BCA jig-borer, due to a huge run-out on the 4-jaw self-centring chuck on an adaptor I'd spent the previous few days making. It is comprised of a recessed disc holding a Myford-threaded nose-piece from RDG Tools; and located on the table by a close-fitting peg.
                So today…
                Investigated.
                First I had to make a set of rods to match my BCA collets and motley assortment of DTI stands to DTIs. I don't know what grade of steel I used, a shaft from a scrapped printer, but it was beautiful to machine.
                Now I could measure things….
                Including making the DTI holder parts, it took basically the entire performance of Siegfried, (yesterday's fight to make two simple nuts took all of Die Valkure), but I traced it eventually to locating-peg.
                Its outer diameter locates the base-plate to the BCA table's central, plain hole. Its inner hole takes the spigot on the underside of the RDG-supplied part. A thin flange adds further locating and stops the pin vanishing into the machine's innards.
                That through-hole, reamed from the far end, was slightly off-centre, forcing the nose-piece to tilt slightly in its nest in the base-plate.
                Reaming it from the top end, with it in a collet on the lathe, removed a surprising amount of metal.
                Re-assembled, the run-out at the top of the chuck was down from a whopping 0.025" to a mere 0.003" I may be able to reduce further.
                I had practically finished by the time of the finale. Just as well, for while I could machine things to most of the opera, even be amused by the art-world thinking that forging iron sounds like a bell ringing; but Brunnhilde's and Siegfried's duet is just too overwhelming for that…
                #528813
                Howard Lewis
                  @howardlewis46836
                  Ah! Drastically reducing the runout must be music to your ears. As long as the machine does not Ring!
                  Glad that you are getting things sorted.
                  #528965
                  Nigel Graham 2
                    @nigelgraham2
                    Thank you Howard.
                    Yes – it was a great relief to find the error was in a small component easy to correct.
                    I had a bit of a lazy day today, perhaps a reaction.
                    I have a pair of Stephenson's Gear expansion-links to make, and dimensions on the drawing I am using as my guide are of course all in 64ths and rectangular. It's occurred to me that if the motion radius is not excessive this would be a good jig-borer task, starting with re-drawing them in polar and decimal dimensions (I use TurboCAD). If it is too large a radius I'll use the same approach but on the milling-machine, with a rotary-table.
                    Went for a longish walk in which I met my sister at her front-door, by sheer chance, so that was a good hour gone with her in the porch and me just outside, trying to talk above the traffic noise. She lives on a main road, but … lock-down?. We live less than half a mile apart but not seen each other since Boxing Day.
                    Still, I gun-blued a few grinder parts, treating them with furniture-polish straight afterwards because if there is one guaranteed way to make steel rust indoors it is to chemically blue/black it then leave it unprotected.
                    Blue? It's a sort of very slightly blue-tinged, mottled dark grey-ish effect. The best blue I have managed on steel was on a set of small spring leaves I oil-quenched, polished then lead-tempered. The steel in the air above the just-molten lead turned a purplish-blue while that left submerged came out still shiny. (They were for the club's "Wren" loco.)
                    Typing this in a break from some tidying and re-organising of the "middle room" (some might call it the "dining-room&quot to create a parking-space for my EW lathe on its trolley; presently partially under the kitchen work-top.
                    And of course, as per the last 3 evenings: we're about half-way through Gotterdamerung at the moment. It's a right tangled plot but the BBC web-site has a synopsis.
                    How do the actors manage to remember so many long, difficult songs with complicated melodies in what to most of them are foreign languages; and understand the lyrics and story enough to sing them with the appropriate voice-expressions, plus remember the cues and stage actions?
                    Right, post this, make a brew and sandwich then back to the re-arranging….
                    #529204
                    JA
                      @ja
                      Finally a warm dry afternoon. I got the saw trestles out on the drive and started cutting timber for a small lathe work bench.
                      I hope to continue posting details of my progress (anything to keep away from “the tea room&rdquo.
                      JA
                      #529207
                      Bazyle
                        @bazyle
                        Posted by Nigel Graham 2 on 20/02/2021 20:16:15:
                        We happend to talk about this on a recent church zoom with a professional singer. Apparently music and or song is stored in an unexpected area of the brain not the normal speach and memory bit. This accounts for why demential patients who can barely talk can sing along to the songs of their youth. Makes you realise how improtant all that school days singing becomes decades later.
                        #529230
                        Gerhard Novak
                          @gerhardnovak66893
                          Small improvement for my lathe – took me a few days as I had to order some material for it. I have some SX25 collets, which I used for milling on the vertical unit of my Emco compact 5. As I have since a few years a Sieg SX2 I practically do not use them.
                          For the lathe itself I didn't purchase a collet holder. As the spindle has an MK2 cone I purchased a cheap MK2 collet holder. I had to manufacture a draw bar to hold the MT2 collet holder securly in place.
                          I have to say – even it dosen't run dead true – It is a world better than my 3-jaw self centering chuck and I love it for small diameter pieces. 20210218_170048 (2).jpg
                          End of the drawbar
                          The whole thing outside the spindle
                          Edited By Gerhard Novak on 21/02/2021 21:16:22
                          #529320
                          JA
                            @ja
                            Posted by JA on 21/02/2021 19:00:23:
                            JA
                            Further to the above threat I will not add to this in "the tea room" but be starting a blog in "The workshop progress thread".
                            JA
                            #530020
                            Iain Downs
                              @iaindowns78295
                              I've watched a lot of Joe Piezinski recently and find myself in awe of his pins – the metal bits not his legs, though no doubt they are fine too.
                              A quick tour of the usual supplies indicates that getting a suitable range of precision pins would require a moderate mortgage – and 0.01mm precision or better is not in my dictionary!
                              So I bought some silver steel (which seems to be generally ground 1 thou under nominal dimension), cut to size, trimmed in the lathe (with surprising accuracy!) and chamfered…
                              This is scarcely what did I do today as it harks back to before the cold kept me from the shed (and camera), but here is a snap of my low profile slitting saw arbour (again inspired by Joe, though I think Quinn's done a you tube on it as well) in action.
                              Finally, I have been attempting to mill the reversing link for my steam engine, which is not going well. Mainly because my masking tape and superglue arbour failed and the part got ruined. I need to start from scratch. Still at least it's almost warm again so I can actually get back in the shed!
                              Iain
                              #530028
                              Nigel Graham 2
                                @nigelgraham2
                                Would be better as "What Didn't You Do Today?" for me.
                                First Covid jab yesterday, and knew I'd quite likely have side-effects.
                                That was in the morning. I drove home (about 43) miles fine, had a meal, pottered about, moved my EW lathe on its trolley to a new location in the house. So far fine; just occasional, slight aches in the jabbed arm.
                                Then started to feel extremely tired so went to bed at about 10pm. Could not sleep though – it always takes me a long time to drop off but I think I managed barely a couple of hours of broken sleep in the next 12 hours. At one time I went through a long phase of bouts of violent shivering despite not feeling cold, but that stopped abruptly and rather eerily. These don't seem on the side-effects list I was given (Oxford / Astra-Zeneca).
                                So today I'm ambling round like a wooden man made of smoke, feeling washed-out, get-up-&-go gorn, no appetite. I am not in a state to risk using machine-tools and no desire anyway; but I'll try to make myself do some engine designing for my steam-lorry – I keep having to revise it.
                                Ah well, I'm sure I'll be right, if not tomorrow than pretty soon. My second dose is in May.
                                #530043
                                Dave Wootton
                                  @davewootton
                                  I'm with you on the what I hav'nt done today or the last few days, Had my covid jab on Sunday morning, felt terrible Monday, same shivery thing as you, and have been a steadily improving zombie for the last few days. All very frustrating, theres loco's to be built, hope the second jab doesn't do the same.
                                  #530051
                                  Howard Lewis
                                    @howardlewis46836
                                    When I was at work, the Technical Rep for one of our Piston supplers gave me a keyring with a small Piston on it.
                                    During lockdown, two of our neighbours, in particular, have been very generous, so I made them keyrings of the same form out of some polished 3/4" Aluminium bar, with a bit of 1/4" steel bar carrying the actual keyring.
                                    Used a 2mm carbide insert parting tool to produce the ring grooves.
                                    Slightly unusual, so not likely to be confused with something else.
                                    Howard.
                                    #530054
                                    bernard towers
                                      @bernardtowers37738
                                      05edd035-a5e7-47df-abd1-c0d861eb4653.jpegNot a good start put hand in drawer and caught it on broken piece of machine Hacksaw blade so that gave me the job for the day turning offending item into two parting blades which is why I got it in the first place(15 years go!). All worked out quite well with angles along blade length ground on the stent.02649069-199a-4205-b726-c4115fe6b2d5.jpeg
                                      #530059
                                      Nigel Graham 2
                                        @nigelgraham2
                                        Dave –
                                        Talking to my neighbour this morning about it, she said from the experiences of others she know is that the worse after-effects are with the Oxford's first dose, and with the Pfeizer's second.
                                        Obviously it depends very much on the individual.
                                        Well, I managed a very light lunch – nothing cooked other than the tea-water. I've just come back in after very gently pottering around the garden in the sunshine, pulling out a few weeds and the like.
                                        Also went into the workshop to measure the travel on the Harrison's compound-slide, taper-length for the planning of.
                                        Iain –
                                        Expansion-links… Not knowing how you were doing it, I don't know the sticky-tape and glue technique but my thought is to drill the eccentric-link holes in the blank, and use them to screw it at the appropriate radius to a suitable plate secured to the rotary-table (Their radius exceeds that of the table.)
                                        Without a rotary-table one way – and an alternative I am considering for myself as I have this problem coming up – may be to make an "arc table" from a length of thick bar or plate. This rotates around an arbour that is basically a large-diameter T-nut stud, and driven by a screw working through suitable brackets etc. on the outer end.
                                        I like that slitting-saw arbour but how do you prevent the cut closing up and jamming the saw by the action of the clamp-bolt, as the saw breaks through?
                                        #530082
                                        Iain Downs
                                          @iaindowns78295
                                          Thanks, NIgel.
                                          The sticky tape and glue goes as follows. Clear well both parts. put some masking tape (I went out and bought some blue philips because someone said so, but it turns out that was what they had not what was needed) on one both surfaces. Apply super glue to the non-sticky side that's up. Push the parts together (tape to tape) and let it set.
                                          It's a variant of the superglue chuck, which is a variant of the wax chuck. I like the tape version (in principle) because you don't have to heat up the parts to break them free. In this case I suspect that the part got warm with the milling – or perhaps I should have taken a lighter cut. Who knows. But I think it's fine to drill / ream with and hten I can bolt it together
                                          I do have a rotary table and started of by mounting the plate on some scrap aluminium and drilling / reaming / slot drilling some registration holes as can bee seen below
                                          As you can see I'm a measure once drill twice sort of guy ….
                                          I've cut another blank and we basically get to the same point and then I will bolt the two eccentric rod holes firmly to the ally. My other challenge is that the centre of the MT3 spindle and the centre of rotation of the table are not in the same place. We're talking 2 or 3 thou here which not going to affect this piece, but it's nice to be try and get it spot on.
                                          The arbour cap has a 22mm protrusion onto which the slitting saw fits. This slides into a receiver on the main body and the two are clamped together with a cap head bolt in a counterbored hole.IN effect there is the same clamping force as on one of those arbours which are far too long and with a long thread protruding with a massive bolt.
                                          This may make a bit more sense.
                                          Iain
                                          #530106
                                          Tom Sheppard
                                            @tomsheppard60052
                                            Put the new lathe in its unopened box behind the motorbike, the bits of which are currently occupying the required space. The engine will be rebuilt over the next week and then the fun can begin.
                                            #530168
                                            Gerhard Novak
                                              @gerhardnovak66893
                                              Played around with my late fathers Stuart 10V, I am almost there. Made the cylinder cover from brass sheet, drilled and tapped for drain cocks. Removed rust where possibel. Finally I painted what needs to be painted, and hopefully tomorrow I can start to put everything together. 20210217_175846 (2).jpg
                                              #530546
                                              John Hinkley
                                                @johnhinkley26699
                                                Towards the lower half of page 5 of this thread, I posted about the lantern chuck that I'd made. To reiterate, it's a blatantly plagiarised copy of the Bernard Towers one in MEW 301, but larger. I decided to increase the number of adaptors to twelve – six plain drilled and six threaded so that grub screws can be accommodated, as well as ordinary fasteners. I can't see myself using 10mm grub screws, but it keeps things neat. I like neat. The whole lot was going to be kept in a drawer (in short supply) or relegated to storage on a shelf (even shorter supply) and thus likely to be subsequently mislaid. So, I ordered a ready-made box from eBay and fitted a shelf inside with suitable cut-outs for the body and main shaft and pins, plain and threaded for the adaptors. Here's what it turned out like:
                                                Lantern chuck and accessories
                                                The small screw bottom middle, which looks like it holds the shelf in place is filling a hole drilled in the wrong place!
                                                Nigel Graham 2
                                                  @nigelgraham2
                                                  Iain –
                                                  Thank you!
                                                  I think you are right about why the glue method didn't work. Yes, you've confirmed for me the other way – screwing the embryo link to an extension-plate – is the way to go.
                                                  I had thought of making the links on the jog-borer but measuring that, found it of too small a radius.
                                                  My main rotary-table is of 6" dia so the links will be overhanging by 2", but I think it'll be OK with a gentle touch. I have a 10" dia rotary table but that's probably too heavy for the milling-machine. I'd have to use the workshop hoist to move and lift it, too.
                                                  I have a commercially-made slitting-saw arbor of somewhat similar pattern, and was dismayed to find after one particular operation I thought I was taking sufficiently gently, the countersunk securing-screw had become so tightened by the cutting forces I had to drill it out, clean up the M8 thread and install a new screw!
                                                  #530602
                                                  mechman48
                                                    @mechman48
                                                    Yesterday & today. Have had a lot of back lash on my WM16 mill fine feed worm drive since day one ( 2012 ) but lived with it since. I decided to sort it as best with out removing the whole worm drive; it measured up at nearly 1.2 mm before the drive engaged ,yeah I know more than excessive. I made up a brass washer to take up as much slack as I figured .041" ~ 1 mm & fitted that, back lash is now down to ~ .4 mm so decided to leave it at that… for now!
                                                    Also decided to remake the cover for my X drive motor from a near colour match 3mm plastic sheet; heat gun bent to shape, replaced a PWM with a new unit that has a on-off-on switch & fitted a numbered dial, looks much better than the original stainless steel version, Original pics in album 'X' drive..
                                                    Fine feed washer…
                                                    Only small stuff but off the Tduit list.
                                                    George.
                                                    #530603
                                                    Samsaranda
                                                      @samsaranda
                                                      Hi Nigel
                                                      Have had the exact same problem with a commercially made slitting saw arbour, very annoying at the time.
