Too cold for the workshop – even if I managed to raise the air temperature to vaguely keep milk fresh, there is not pleasure in handling cold machine-tools, and that's not conducive to decent work…
SO…
A little design-work on the steam-wagon engine.
Then
Tried cold-blueing various steel parts for my Worden T&C grinder, using "gun blue" bought on-line from a country-sports stockist. I'd had to turn off the filters I'd set on my computer so it would accept the word for that which is fired, though I noticed the catalogue did not even mention "bang-sticks".
The chemical is applied to the degreased steel by swab (I used cotton buds) and left for a short while to work. Then you rinse the parts in cold water, dry them and according to the instructions, gently polish them with fine wire-wool.
I obtained rather mixed results that one would not want alongside one's polished Hunter wellies and neatly-ironed waxed-cotton.
Not sure why the patchiness, but I now wonder if my mistake was degreasing the components in methylated spirits, and perhaps not sufficiently. I will have to experiment before treating the remaining parts, e.g. using a final wipe with xylene paint thinner, or rinsing in hot washing-soda solution then boiling water. I was careful to wear rubber gloves, both for my protection and to avoid contaminating the cleaned steel.
The gun-blue makers recommend you then protect the blued surface with a special oil (which of course, they also make, along with the special degreaser that's probably only alcohol or acetone).
Well, I was trying to avoid oily surfaces on a grinder, and thought that since shooting is an outdoor activity, gun-blue would be a more protective finish than the only chemical blacking I could find listed by "our" suppliers. Its sellers, Chronos, does warn that the coloured layer still needs oiling or lacquering to protect from rusting. I have used spray-on furniture polish, which does not last forever but seems quite effective for a reasonably long time.
Edited By Nigel Graham 2 on 12/02/2021 17:20:40
