Posted by Kiwi Bloke on 17/07/2021 02:30:09:
Posted by Anthony Knights on 16/07/2021 10:21:29:
… I just cannot get on with the crappy lead free stuff. …
You're not the only one! It keeps the electronics repair people in business, however, being responsible for far more solder joint failures, and other problems, than 'proper' stuff….
Quite amusing, there's a moan in one of my 1940's A5 sized Model Engineering magazines that proper tin solder was replaced by 60:40 rubbish as a war economy, and the cheapskates never fixed it.
In practice, the alleged unreliability of tin solder joints seems greatly exaggerated. Going back 20 years, much concern was expressed that lead free solder would increase the problem, but at that time there was no understanding of what caused whiskers to form and it was assumed lead in solder reduced the effect. Later research suggests lead-free solder is innocent, or at least much less whisker forming than feared.
My life is full of electronics, and – so far – I've never seen a failure caused by growing tin whiskers. Dry joints, electrolytic capacitors, corrosion damage, resistors changing value, static electricity, water, tired fuses, insulation damage, cracked tracks, tracks lifting off the board, yes. I'm not saying tin whiskers don't exist, or that high reliability electronics can't use lead, but lead leaching out of landfill into the water supply is a serious problem. Irresponsibly dangerous. Not because hobbyists use a bit of 60:40 solder, but because industry make billions of electronic boards every year. In 2000, about 80000 tons of lead solder per year. Anthony's 500g reel isn't the problem, it's the other 160 million!
And Anthony needs a new soldering iron. Tin solder is difficult to use if the iron isn't hot enough. So is 60:40!
Edited By SillyOldDuffer on 17/07/2021 11:27:09
