Finished lapping piston to bore. With polished piton a stiff fit in the ends of the bore I lapped out the cylinder to fit as that way I could address the tight spots tight spots in the middle.
To finish I jammed the piston on a turned in place wooden plug and lapped it to the cylinder. Silver/brass polish wouldn't quite finish the job so I resorted to Autochrome (like Autosol) which is horrible to clean off before you can test the fit.
VERY chuffed though because the cold piston will drop through the cylinder, but warm it in my hand and it sticks.
If cold piston is sealed with blu-tack it won't drop when I cover the end of the cylinder, but drops when i move my thumb, which is the fit the designer says aim for, so fingers crossed.
Now can anyone guess what it is?
