Hi Chasps: since buying a crosswork table I hit one of those dilemas which "I didn't think that through." syndrom reared it's ugly head. I slept on my choices which were send it back and get a smaller one or modify my drill stand to make it taller. In case you don't know I am going to use the table for spot drilling with the hope that my drilling becames somewhat more accurate.
Come the morning I trapsed over to my ex works and was soon in possession of a piece of 45mm dia bar. Back home and blow the Lathe will only take 300mm between centres. So yes I had to saw it in half with a hack saw, ugh!
Next I shaved the bar down at one end to 43mm dia. Easy peasy with my taper roller bearings in my little yellow lathe. Now over to the Micro Mill, Clarke CMD10 to whittle a grove to clear the seam of weld on the inside of the tube which supports the head of the drill. Yeay the darn chuck spun off and put a dig in my leg. Replaced it butting the chuck on tighter using a bit of oak so as not to mess up the cutter and this after cleaning the taper. Well we struggled on me and my yellow mill and since nothing had to be thou accurate I took the shaft off the mill when the groove measued .4mm deep.
Now will it fit? No I had to reload to the lathe a couple of times apply a bit of emery cloth. Try again mmmm nearly there. Darn it, it's stuck, can't get the piece out . A cup of coffee later and a leather mallet in hand and it was home snug as a bug in a rug.
I'm looking at the drill press right now with just one thing left to do and that's swop the heavy end to the bottom of the stand.
Makes ones day when there's a little sucess.
Jesse
Edited By Jesse Hancock 1 on 10/01/2015 20:16:45
