Got the new Warco WM250V mounted on the bench, so far quite impressed with the build quality, now to strip it down give it a damn good clean then on to the modifications, this is destined to become a CNC lathe. Need to tweak the inverter settings as the ramp up is a bit on the slow side for my liking, One thing I have noticed is the gear train is damned noisy, especially compared to the gear noise from my GH1330!, the gears on these lathes are quite a large module size and ring like a bloody bell!. Not going to worry about that too much as they will all be removed in the CNC conversion.
I'm thinking of 5mm pitch ballscrew for the leadscrew and 2mm pitch for the cross slide, – anyone have any thoughts/opinions on this?
Top slide will be ditched as there's no requirement on CNC machine and looking to implement an auto tool changer using a small rotary table I have kicking around.
Also plan to change the chuck mounting not sure how yet but I hate fiddling around with those silly nuts behind the spindle flange
Thinking of mounting a backplate permanently and using front mount chucks.
