Hi Shaun,
I imported my Tormach in June last year, however one thing I underestimated was the space required for the installation of the mill. I had done some basic measurement of the workshop to see if there was room for the footprint of the mill. It looked OK in theory, however when I got the mill I realised that I would have to completely re arrange my workshop.
At the time I ordered the machine I was working in the Oil Industry offshore on a two weeks on two weeks off cycle. That may sound Ideal to most folk but it isn't, you arrive home completely knackered and your head is at sixes and sevens for the first two days so it is not worth doing anything for the first couple of days home. I have ended up with more jobs in the scrap bin in the first two days off that at any other time. I also had to travel back a day before due to the flight schedule, so you are down to 10or 11 days that can be productive, however, with family commitments, such as babysitting for my youngest daughter in London every other weekend it leaves little time to do any jobs that require any continuity.
It didn't take too much to build the machine up and install the 4th Axis driver and other accessories such as power draw bar and ATC but the re arrangement of the workshop took the time, mainly because the place was like a bomb site ( in order to get the mill into place I had to scrap various things such as a set of shelves and a storage cupboard). This made things slow and difficult. I retired from offshore work in December (Probably just in time because I probably would have been out of work some time in 2015 due to falling oil prices), this has made a major difference and I was able to concentrate on sorting out the workshop, firstly by installing as much new shelving as I could to clear the clutter that was everywhere, then secondly by building a fitted workbench for the Mini Lathe, tool & cutter grinder and bench drill.
In doing this I have transformed my workshop and it is much more pleasant to work in.
While working offshore over the last year I have been able to concentrate on reading as much as I could about CNC machining as well as trying to get to grips with 3 D Cad and the CAM programme (Sprutcam) but reading about it is no substitute for the real thing and in the last couple of weeks I have been slowly and systematically generating a drawing and programme to produce my first part, so in answer to your question I am fairly green but getting into it and so far enjoying it too.
The only advantage I have is that I am not too bad with Autocad 2D which I have found has helped me a lot with both the CAD and Cam software.
In my reading about CNC milling I also read about the advantages of climb milling etc and it makes sense with low power machines as long as there is no backlash.
