What did you do today? (2014)
Home Forums Work In Progress and completed items What did you do today? (2014)
Viewing 25 posts - 276 through 300 (of 2,328 total)
  • #147085
    Brian Wood
      @brianwood45127
      Chopping out tired cement and repointing the longish gaps today. Hopefully that will thwart leakage from driving rain and gale force winds in the future. There is still silicone sealing up to a window sill to finish it off and then Thompson's water seal for good measure. Amazing stuff, I've seen water running off gravel that it has got onto.
      Building work 3, workshop 0..
      Feeling righteous though as a result and I must be in for brownie points too!
      Another JohnS
        @anotherjohns
        Did not quite get the Printrbot Simple 3D printer together – the power supply is DOA. Oh well…
        A bit more on my blog, as usual, for those interested: **LINK**
        Edited By John Alexander Stewart on 14/03/2014 18:12:31
        #147100
          Hi John,
          Dogs can be amazing. As a boy my little brother got wasps in his hair when we were camping. My mum was trying to get them out and our dachshund took over and finished the job. He was stung all over his jaws.
          Clive Hartland
            @clivehartland94829
            Brian, dont put Thompsons waterseal below the damproof course, if you do, the damp that rises through the bricks below the damp course will not be able to evaporate. I only did the weather side of my brickwork, spray it on as it just disappears into the bricks.
            #147122
            Brian Wood
              @brianwood45127
              Hello Clive,
              Good advice thank you, but I was aware of that risk. The job in hand was at upper level, the weather leakage was coming through the ceiling in the sideways extension below. Finishing work today as said, but the pleasant sunshine has gone and is replaced with grey cloud and a cold wind.
              Ah, well.
              Regards Brian
              #147131
              OuBallie
                @ouballie
                Ah, I only counted the wheels on the trailer. Forgot that the hitch is also described as a wheel.
                Last night had another go at the drawer organizing saga that is now starting to annoy me
                Later did more work on Yuri's TouchDRO box of tricks. Must say that the scales from Ketan's emporium are excellent.
                Geoff – Starting to feel better
                Edited By OuBallie on 15/03/2014 10:18:09
                #147145
                Oompa Lumpa
                  @oompalumpa34302
                  Today I went off and collected my new Dividing head, cleaned her all up and fitted a four jaw self centering chuck.
                  She is Bootiful!
                  Any suggestions as to what I could actually use it for would be gratefully receiveddisgust
                  Meanwhile it makes a statement in my workshop – "looka me, I really know what I am doing!"
                  Made me smile anyway.
                  graham.
                  #147148
                  David Colwill
                    @davidcolwill19261
                    They are particularly good for stopping drawings blowing off the bench when you open the door.
                    David
                    #147149
                    Rik Shaw
                      @rikshaw
                      "Any suggestions as to what I could actually use it for would be gratefully received"
                      How about using it to create a load of swarf to scruff up your impossibly clean workshop? (That's a nice bit of kit though).
                      Rik
                      #147150
                      Derek Drover
                        @derekdrover32802
                        Put my 3 1/5 Netta through its 4-yearly hydraulic test – passed, then the general steam test. Not only did she pass that, but even the damned injector worked !!!!!!!!!!!!!!!!!! Now that's a first !!!!!!!!!!!!!!!!!!!!!!!!!!!!
                        Yes.. I'm HAPPY !
                        #147151
                          Graham,
                          You must now make an orrery!
                          Oompa Lumpa
                            @oompalumpa34302
                            Posted by Neil Wyatt on 15/03/2014 19:07:31:
                            Graham,
                            You know Neil, I always wanted one. I would be very grateful to everyone if you would NOT send me the plans for one or I am likely to lose a significant part of my life
                            I am not surprised at the cost of some of the kits.
                            It would stop a thick wad of plans blowing away, I wouldn't like to drop it on my toes!
                            graham.
                            Edited By Oompa Lumpa on 15/03/2014 19:25:20
                            #147154
                            Gray62
                              @gray62
                              Graham, you should add a stepper motor and indexing controller like a division master or the one designed by Steve Ward (world of ward) has all the details. The latter has all the functionality of the division master but works out a lot cheaper, I have built both. Ditching the index plates and going the stepper route helps prevent making 71.5 tooth gears instead of a 72, like wot I did!!
                              Edited By CoalBurner on 15/03/2014 19:49:38
                              #147155
                              Nicholas Farr
                                @nicholasfarr14254
                                Hi, Well today I changed these two wheels on my Bedford cement mixer ( which look like belt pulleys off some piece of farm machineary, to me) and the axle.
                                To these two wheels ( which came from a pair of redundent trailer suspension units) and a new fabricated axle.
                                There are some photos in this **LINK** of the main fabrication points, for anyone who is interested.
                                Regards Nick.
                                #147157
                                  I wouldn't worry, it will make jobs that you could do with a more simple head a greater pleasure to do, and one day you will need something set out to an exact angle or a prime number of divisions!
                                  If you're like me you will find something to do just to make use of it.
                                  I have a fascination with Jupiter and the four Galilean moons, because they are so easy to observe (especially at the moment – go outside at 9:00 and look south and high – half decent binoculars should show you the moons). So a Jupiter system orrery might be fun and simple(ish)
                                  Apparently the four inner moons have locked together orbital periods in the ratio 1:2:4 (something called Laplace resonance). The outer, Callisto has a period 9.4336 time that of Io. 9:85 is just over one part in a 1000 out and could be used as the basis of a gear train, say 18:68 and 20:50 which gives 1:9.44, an error of about 1/5 of an orbit over an earth year. Can anyone do better?
                                    I made a few piston rings for the Monitor
                                    The next part needed a dimension taken from the engine so I put it all together for the first time, its quite an impressive size when assembled.
                                    #147159
                                    John Stevenson 1
                                      @johnstevenson1
                                      "Can anyone do any better ? "
                                      Yup.
                                      How about 9.433673469387755 ?
                                      Which is 14:43 / 14:43 which has an error of 0.00000083 if your figure is accurate at only 4 decimal places.
                                      If you use 3 pairs then 15:32 / 25:22 / 25:67 is exact with no reported error at 0.0000000001 places.
                                      Edited By John Stevenson on 15/03/2014 20:53:21
                                      #147161
                                        How did you do that? I should have used a spreadsheet instead of a calculator.
                                        Two pairs of identical gears should make a design simples!
                                        Well it's taken me about 5 minutes:
                                        Jupiter on a fixed central spindle
                                        Io on a outer rotating sleeve.
                                        15:15 10:10 drive Europa on a second sleeve
                                        15:15 10:20 drive Ganymede from that second sleeve.
                                        14:43 14:43 drive Calisto from the first sleeve.
                                        Best of all, the teeth numbers are such that either 1 mod gears would be a sensible size to use.
                                        Thanks John.
                                        Edited By Neil Wyatt on 15/03/2014 21:07:12
                                        #147162
                                        John Stevenson 1
                                          @johnstevenson1
                                          Posted by Neil Wyatt on 15/03/2014 20:56:11:
                                          If I told you I'd have to kill you.
                                          #147165
                                          gary
                                            @gary44937
                                            lovely job on the moniter watching with great interest jason
                                            #147168
                                            Boiler Bri
                                              @boilerbri
                                              It makes me sick looking at all your progress, working full time leaves me no time or effort to do anything. Role on retirement.
                                              Bri
                                              #147187
                                              Four stroke Fred
                                                @fourstrokefred
                                                Thanks for the comments. I must say that being retired does help with the continuity of work and thought processes. When I was working the weekends always seemed to be more than 5 days a part! I do get quite a few visitors to the shed but really don't mind if it helps to spread the word of model engineering and encourages others to take up our hobby.
                                                #147188
                                                  Bri give it another 20yrs when I reach retirement age and I'll reallly start knocking them out!
                                                  Garry, I'll start a full blown build thread in te next week or two, have you made any progress on yours?
                                                  J
                                                  #147224
                                                  gary
                                                    @gary44937
                                                    looking forward to your new thread Jason, I haven't started on my monitor yet as I am determined to get the r&b running , but might set aside if no success this week!
                                                    #147239
                                                    Boiler Bri
                                                      @boilerbri
                                                      Thanks for that Jason. I managed a couple of hours today so finished the axleboxes for my Sweetpea. Progress
                                                      Bri
