Bill, On your mantle clock, it's anyone's guess what could be wrong with it, but it's probably well overdue for a bit of TLC and bone dry of oil on the pivots, plus, generally if it stopped after winding, it's probably the mainspring that's dry and gummed with old grease and possibly 'set' due to old age and fatigue (tell me about it)!
When this happens, the coils get stuck together and no longer transmit power, this also applies in the same way to wristwatches which are then usually dubbed as being 'overwound'
If the minute hand was seized, it could be anything from dry or badly worn pivots to something gone awry on the striking mechanism, (if it's a chimer) which usually happens when the hand is somewhere near the '5 to' position and tripping the warning for the strike, but if it's just a timepiece, then dry pivots and muck!
Even worn out old dogs will generally tick away like crazy when the pendulum is removed, even if miles out of beat because there's no mass of the bob to impulse!
I doubt it will be out of beat suddenly unless SWIMBO gave it a monumental shove, however, some mantle clocks have a self setting facility for setting in beat, you can check this on yours with the movement being out!
Try pushing the solid part of the crutch to one side (not the loose leader rod if fitted) until the pallets lock on the escape wheel, then push a tad further to move the crutch on the pallet arbour, if it moves very easily, it's probably self setting, if it's tight, then it's a traditional friction collet to allow the crutch to be moved and stay put in that position, if it won't move at all, bad luck, it's the type that requires the crutch rod to be bent to set a clock in beat and can be a right PIA to get spot on!
For self setters, move the pendulum well to one side and let go, the pendulum will eventually settle down into a normal rhythm and in beat!
What you could try short term Bill, and if you're feeling brave, is let down the mainspring(s) to release the coils, but it's only really a short term check to see if they are stuck, and if so, you'll hear and feel them thud when the coils let go, to do this, take off the dial and look for the ratchet wheels on the winding arbours, against these you'll see the clicks with a spring bearing on them!
Fit the key and 'wind' Just sufficient to release pressure on the click, then hold the click off the ratchet wheel and clear of the teeth by pressing on the 'ear' of the click, then gently release 'some' of the spring tension and re-engage the click, keep repeating this until fully unwound,
Warning! be Very Careful doing this, because if you drop your guard or lose grip on the key for a nanosecond, it'll give your fingers a monumental rap leaving your DNA all over the front of the clock and wherever else the ears on the key centrifuge it as it emulates a propellor!
The upside (when the pain subsides), is a nice warm glowing sensation in your fingers, the downside, (apart from flesh sprayed around and pain for a while when washing hands) is that the inner coil of the spring which once grabbed the hook on the barrel arbour now probably won't because of the recoil, and will require the clock stripping anyway to rectify said damage !
Don't ask me how I know!
A good tip for letting down clock springs, is to cut a slot in an old door knob for the ears of the key, then shove it over the key, gives lots of control and avoids self mutilation!
When you've done all that, put a spot of oil on all visible pivots and wind the clock up again, if it's still dead, time to get the spanners out, and if you've never done one before, I recommend a digital camera too to capture images of all the scary bits ………….. especially on 3 train Westminster + Whittington chimers!
Edited By RJW on 03/04/2013 15:10:54
