Posted by John Alexander Stewart on 21/10/2012 02:40:05:
My Worden table risers, hot off the press, so to speak. Rather than mounting them in the lathe, I just did them on my CNC mill. 3 3mm thick sheets needed turning on outside, with offset hole, and 2 holes for screws to mounting arbours.
I should probably take another picture, but the plates and mounting bushes, etc, are all done. I found a tiny bit of eccentricity; I think that it's because I put in a bit of backlash compensation in the Y axis, and *then* took the mill apart for inspection and cleaning.
Anyway, a tiny bit of filing made the bush holes ok, and the outsides – the eccentricity does not matter.
At least my little KX1-NU cnc machine works pretty well on steel, and I know I need to have another look at that backlash compensation stuff.
Another JohnS.
