What did you do Today 2024
Home Forums The Tea Room What did you do Today 2024
Viewing 25 posts - 1 through 25 (of 530 total)
  • #703254
      Use this thread just like you did all the previous one.
      Robert Butler
        @robertbutler92161
        Thanks Jason
        You normally post a link to the previous years thread.
        Robert Butler
        #703327
        noel shelley
          @noelshelley55608
          Get up, light fire, make coffee and now think what to do ! Noel.
          #703341
          Paul Kemp
            @paulkemp46892
            I managed to log in!
            Paul.
            #703369
              Not much so far,
              but my daughter sent a delightful advert from 1982 which should stir a few memories: Does anyone fancy doing a Moore’s Law calculation ?
              IMG_6819
              #703434
              jaCK Hobson
                @jackhobson50760
                I have finished my pointy stick. Made good use of my ELS to turn the pommel. I did find some shortcomings or ‘missing features’ of the ELS – you can’t crown a wheel (or pommel), and you can’t ‘fast forward’ through a many step sequence if you just want to tweak the final dimensions a little.  415116709_10232122245303447_4945769233175494449_n
                IMG_20240101_172116
                #703548
                  Just found a useful little project : A tiny spot-welder
                  https://www.youtube.com/watch?v=jCguxDdDbf4
                    and in case you blinked:
                    Complete with some trivial typographical errors …
                    Screenshot 2024-01-02 at 11.25.49
                    #703587
                    duncan webster 1
                      @duncanwebster1
                      There was a similar device described in ME or MEW some time ago.
                      Building the circuitry in fresh air is asking for trouble, a bit of veroboard would be much better
                      #703706
                        Yes
                        #703708
                          On Robert Butler Said:
                          Thanks Jason
                          Robert Butler
                          I think he did, Robert
                          [ or was that sneakily inserted as a result of your post ? ]
                            Bazyle
                              @bazyle
                              It is amazing how things come and go over the last 45 years. VCRs, CDs, 8 bit micros, but the 555 is still going strong. My first day in paid work was to knock up a timer…..
                              #703819
                              simondavies3
                                @simondavies3
                                On Michael Gilligan Said:
                                Not much so far,
                                IMG_6819
                                The 1st PC I ever used….and when I went to the Science Museum before Christmas, what did I find on display as part of the “History of Computing” section:
                                TRS80 crop
                                #705260
                                duncan webster 1
                                  @duncanwebster1
                                  Bored out some sprockets and made some axles
                                  IMG_20240106_190921
                                  #705503
                                  Harry Wilkes
                                    @harrywilkes58467
                                    Replaced the bottom in the twin cupboard under kitchen sink. Discovered a pinhole leak in the pipe above stopcock New Years Day got it fixed next day but it must have been weeping for a while which help me to pull it out easily. Got a new bottom cut to size just needed a slot cutting for around the water pipe and job done.
                                    H
                                    #706303
                                    Craig Brown
                                      @craigbrown60096
                                      20240111_204715
                                      Produced lots of swarf roughing out a riser block for my mill
                                      #706312
                                      bernard towers
                                        @bernardtowers37738
                                        Put it together today but not run it yet
                                        IMG_3377
                                        #706485
                                        John MC
                                          @johnmc39344
                                          Just trepanned the centre out of a 200mm diameter disc of steel, twice.  Posted have a go with photos in the “new” forum.   Need to find out how to resize photos!
                                          Trepanned disc1
                                          Trepanned disc2
                                          #707362
                                          Mark Rand
                                            @markrand96270
                                            Stripped the ML7 down to overhaul it before selling it. I measured about 1/4 thou of wear to the top of the bed and 1 thou of wear in the vertical sheers. Shouldn’t take too long to scrape that out. I haven’t measured the cross slide dovetails yet. I wouldn’t be surprised to find that they are worse than the bed.
                                            The lathe’s been in the family since 1967.
                                            #707516
                                            Ady1
                                              @ady1
                                              A TRS 80 was my first computer
                                              But even a decent keyboard wasn’t possible at the time, it had those clicky-calculator buttons which helped to drive you insane as you tried to learn
                                              https://www.ebay.co.uk/itm/124397313263
                                              Anyroad, got my CZ bender upgrade finally done in steel
                                              S4020001
                                              #708211
                                              Craig Brown
                                                @craigbrown60096
                                                20240118_142903
                                                Checked how parallel the riser came out. Just over 0.01mm (pretty well 1/2 a thou) thicker one side to the other which works out perfectly as that is basically the difference I need to correct some nod out of tram I have
                                                #708323
                                                Nigel Graham 2
                                                  @nigelgraham2
                                                  Ventured into the workshop for the first time for too long, boots crunching on the frosty grass, stopping to fill the bird-feeder en-route down the garden. Eating me out of house and home they are, the sparrows.
                                                  Set up the first of the two new steam-wagon connecting-rods, to mill their flats. I’d made the first ones much too short.
                                                  They are turned from 40mm bar, fitted with full-block, split cast-iron big-ends. I slightly modified a couple of small ‘waif-&-stray’ angle-plates (they look home-made) to be bench-centres with temporary big-end studs holding the assembly to one angle, and a mild-steel centre in both.
                                                  Most of me was reasonably warm with the unheated shed’s door closed, but despite trying to work in gloves, my hands were becoming unpleasantly cold from the chilled machine-tools, and I stopped at a strategic point to retreat to the house.
                                                  #708438
                                                  Ady1
                                                    @ady1
                                                    The temperature was a balmy 3 degrees today, the last 10 days or so have been pretty tough with the sub-zero weather.
                                                    Even the sparrows are shouting today
                                                    #708485
                                                    Harry Wilkes
                                                      @harrywilkes58467
                                                      Trepanned disc1
                                                      Trepanned disc2
                                                      John I just click on the photo it should turn blue then just ‘grab’ a corner pull it in until you got the size you want
                                                      H
                                                    • The topic ‘What did you do Today 2024’ is closed to new replies.
