What Cutter For Big Cuts On A Small Mill?
Home Forums Workshop Tools and Tooling What Cutter For Big Cuts On A Small Mill?
Viewing 7 posts - 26 through 32 (of 32 total)
  • #551142
    Roderick Jenkins
      @roderickjenkins93242
      Posted by martin haysom on 24/06/2021 11:14:12:
      Posted by not done it yet on 24/06/2021 10:32:20:
      a desire to get the job done in reasonable time.
      drilling is to slightly less than tapping finished size.
      I would rough screw-cut the threads and finish with a tap (under power in the lathe?) – likely saves time compared to getting the single point threading just right.
      sorry i am confused if you got a tap why not drill it the correct size and tap the thread
      Have you tried tapping 1 1/8" BSW? Half inch is hard enough smiley
      Rod
      Anonymous
        It'd take some pretty hefty machinery to drive a 1-1/8" BSW tap under power. Similarly you'll need a large workshop gorilla to drive the tap by hand, as well as the problem of keeping it perpendicular. It's simpler to rough out by screwcutting and then clean up with a tap. Of course it may well be that the OP doesn't have 1-1/8" BSW taps, in which case screwcutting is the way to go.
        I have a set of 1-1/8" BSW taps; I'd go the screwcut and then tap route if I needed to use them.
        #551151
        William Chitham
          @williamchitham75949
          Posted by Andrew Johnston on 24/06/2021 11:32:34:
          Posted by martin haysom on 24/06/2021 11:14:12: Similarly you'll need a large workshop gorilla to drive the tap by hand, as well as the problem of keeping it perpendicular. It's simpler to rough out by screwcutting and then clean up with a tap.
          I wanted to do the job without spending a lot on tools so I cut a test thread using one of the old nuts to check it. It wasn't till I'd made the test thread a little undersized that I realized that the sample nut was distorted so at that point I chickened out and bought a second hand tap to finish off. My gorilla was off that day so I had to do it myself and even though the tap was only taking off a smidgin I still needed 12" of scaffold tube on the end of a 12" wrench to turn it. Not the sharpest tap maybe but still, I definitely wouldn't fancy my chances of doing that way from scratch or getting the Boxford to turn it even if I could hold such a tap in the tailstock.
          William.
          #551155
          noel shelley
            @noelshelley55608
            Andrew beat me to it ! You would need a BIG lathe to turn a 1.125" whit tap, even in back gear ! Noel.
            #551157
            Circlip
              @circlip
              "a desire to get the job done in reasonable time."
              Ahhhh Tempus Fugit.
              Regards Ian.
              #551164
              Dave Halford
                @davehalford22513
                Posted by not done it yet on 23/06/2021 18:50:42:
                Dave,
                I don’t have a plasma cutter – I might get one of the lidl offerings if I ever get the opportunity (some hope of that happening in my local lidl!) but no chance of cutting 25mm. Certainly I will never need a machine capable of a clean 25mm cut.
                The bandsaw (with a kerf of about a mm) might at least offer the opportunity of making an approx 5mm ‘waste off-cut’ that might be useful sometime.🙂
                I am wondering how William is currently cutting his 42mm pieces from his 50mm (42mm) bar…. and how he intends removing the 8mm (from the long bar, or a stack of short pieces clamped securely together🙂 .
                Edited By not done it yet on 23/06/2021 18:51:50
                Lidl one, unmoded (they can be adjusted to 40A) will cut 3mm easy, 6mm slowly
                #551173
                  Bigger spanner might have been the easiest optionsmile p
                  Nice job on the nuts particularly the washer face detail on the underside.
