What am i doing wrong
Home Forums Beginners questions What am i doing wrong
Viewing 12 posts - 26 through 37 (of 37 total)
  • #456636
    Martin Kyte
      @martinkyte99762
      Certainly the geometry that George Thomas proposed as best for boring bars had a front angle greater than 90 to the bore behind the tip. I suspect that this is one of those instances where the design of inserts gives the most utility for modern industrial machines where the problem doesn't appear with their auto or CNC feeds and huge rigidity.
      We on the other hand sometime have to fall back on older methodologies.
      regards Martin
      #456669
      Steviegtr
        @steviegtr
        Wow . You have all given me plenty to think about. Ketan, thank you for the info on the boring bars, Mine is flat on the top & round at the bottom to locate in the 250-102 holder. I will include a picture showing shape & part No. Neil sorry. I have gone & cut the end of the bar off to work on, that had the writing on it. Sure it said EN1A. The guy said it was the best for machining, he had others. The stainless I machine is 316. Not had a problem with that. Sounds like I need to change the tip & run much faster.
        Also I may have been misleading with my 1st post. I was turning a 6 degree taper to make a cone for ring making. I offset the compound to achieve this. Yes the stick out was 3" , which I needed.
        The other thing said was the cross slide & compound chatter. I did lock the cross slide so it could not move & I recently stripped & adjusted it, There is no chatter in that. The compound was a little loose & I could rock it slightly if I gave it a hard twisting motion. So I nipped the gib screws on 2 of the 4. It seemed to do the trick, although made it a bit stiff to turn, Hence my aching fingers.
        Strangely as someone said I could get a better finish when backing out of the work. I thought this was maybe because in the way in you are removing metal & on the way out it is taking a much shallower cut.
        Anyway I have read through all that has been said & will take it all in & try again, I do have a slightly smaller one to make so will see. Busy tomorrow picking up the dismantled 370Kg milling machine. So may have a back ache too. Regards.
        Edited By Steviegtr on 11/03/2020 19:27:28
        #456670
        Steviegtr
          @steviegtr
          Posted by SillyOldDuffer on 11/03/2020 09:32:05:
          Posted by Steviegtr on 11/03/2020 01:06:00:
          Also just a mention the steel was marked up EN1. I bought from a guy at Rufforth who sells nothing but bar stock. I have spoke to him at length so I do trust him. Ex Coded welder. So he knows his metals.
          Steve.
          EN1 is 'ordinary' mild-steel of the type I warned about. It doesn't machine particularly well. (Nor is it avoid at all costs horrible.)
          EN1A is markedly better on a lathe because it's formulated for machinability. The specification includes the magic words 'free-cutting', and it's roughly twice as machinable as EN1.
          Best of all in the family of mild-steels is EN1A-Pb. It contains Lead, and is about 50% more machinable than EN1A.
          Machinability isn't an obvious concept, but the techniques needed to cut anything vary tremendously. At a pinch a wood-saw can cut butter, but don't use it on steel. Likewise Lathes and Milling machines don't cut all metals equally well, or at all! Try turning a square file into a round spike.
          Beware who you take advice from, including me. A Coded Welder will certainly know about metals, but his focus is welding not machining. Different skill set. For example, a Welder should avoid EN1A and EN1A-Pb because they don't weld well! Your colleague may be completely trustworthy in the ordinary sense, but this is engineering. It's fact based, look it up in a book, confirm by experiment knowledge. Judgement calls influenced by a firm-handshake, old-school tie, convincing patter, or solid friendship aren't a good way of making workshop decisions.
          Other way round when dealing with people because most of us are an emotional mess! Then personal trust matters big time.
          Sorry it did says EN1A. My mistake. Dave the other thing you mentioned about trusting people. The reason I said it was because the guy's mum & dad ran the steel stock business for many years , He helped out when he could. Sadly on the way home from the Newark autojumble some time ago, his dad had a heart attack & passed away. His mum gave up on the business , so he took over. The company is called Blenco metals, of Doncaster. I spent an age talking to him because I worked for many years on Oil refineries. It seems he has worked as a welder at all the plants I had worked at. Anyway I digress, but he does seem to know his steel, from helping his Dad over the years.
          Steve.
          Edited By Steviegtr on 11/03/2020 19:44:12
          #456696
          Mick B1
            @mickb1
            Posted by Steviegtr on 11/03/2020 19:24:01:
            Steve.
            Sometimes I've wondered if that effect is due to the workpiece (and tool, if it's a boring bar) being in tension from the cutting force rather than compression. That might tend to damp out vibration and chatter rather than amplify it.
            Maybe…. laugh
            Edited By Mick B1 on 11/03/2020 21:04:07
            #456699
            Steviegtr
              @steviegtr
              You could be right. I did try a 10 thou cut from inner to out & it was hard going. The 10 thou cuts is what I did the cone with, I think some have said even less is better. Definitely need to design & make a neat little attachment for the handwheel on the compound. I know a lot use a battery drill.
              Steve.
              #456701
              duncan webster 1
                @duncanwebster1
                I don't understand why a flexible boring bar would cut a tapered hole. There might be some bell mouthing as the cut comes on. But once the cut is established, and the bar has deflected by whatever it wants, then the cutting process is stable and the diameter of the work won't change. The diameter might not be what you expect, but it won't be tapered. That's definitely my experience. It's counter-intuitive but the best way to kill chatter when boring is increase the depth of cut and/or the feedrate. The boring bar may deflect a little more, but if the cutting process is stable then the bar will not chatter.
                Unless the workpiece itself is deflecting I agree, and on a boring operation the workpiece will be a lot stiffer than the boring bar. I'd also point out that the stiffness is governed only by the shape (diameter) and overhang, as long as it is steel the young's modulus won't change by using a 'better' grade. The seating of the insert in the recess at the end is a different matter, I can easily believe that Sumitomo bars support the tip better and stop it moving about on its seating, also present it at the correct angle
                #456727
                Steviegtr
                  @steviegtr
                  Posted by duncan webster on 11/03/2020 21:48:42:
                  SORRY guys it was not cutting at an angle . I set it to cut a taper at 6 degree's. That was not the problem. The problem was a poor finish to the cut. The Arc boring bars do look very good & much more so than the one I have.
                  Steve.
                  Edited By Steviegtr on 11/03/2020 23:01:05
                  #456755
                  Anonymous
                    Posted by Steviegtr on 11/03/2020 23:00:07:
                    Errr, we'd worked that out. Despite what you might think we're not complete numpties. We're talking about a different sort of tapering, as raised by Ketan. I doubt you're problem is due to the borinmg bar, more likely to be the insert and technique.
                    A helpful sequence for use on forums is read, understand, post. smile
                    #456758
                    Danny M2Z
                      @dannym2z
                      Maybe a lick with a toolpost mounted grindiing tool could smoothe things out a bit smiley
                      #456796
                      thaiguzzi
                        @thaiguzzi
                        1. Boring bar as big as fits in the hole.
                        2. Two hands or digits on the top slide hand wheel. Lock everything else down.
                        3. I prefer sharp HSS on anything inc internal tapered bores if i want a super finish.
                        4. Stating the bleedin' obvious – yes, on centre with the cutting edge every time.
                        Along with all of the above, and a smooth, well oiled, no slop movement on said top slide, i can get perfectly workable, wonderful finishes on 2MT internal tapers on a 51 year old Boxford.
                        TG.
                        #456808
                          Posted by Steviegtr on 11/03/2020 19:31:21:
                          Steve.
                          EN1 is 'ordinary' mild-steel of the type I warned about. …
                          Sorry it did says EN1A. My mistake…
                          Steve.
                          OMG, my mistake, not yours Steve. Just got back to this thread to discover I blundered yesterday. Although EN1 was buzzing loudly between my ears, I was actually thinking about EN3. Wires crossed completely, hence my embarrassing essay. Possibly due to old-age, more likely carelessness!
                          Andrew's comment about the advisability of reading and understanding posts is all too pertinent. In my case, I clearly ought to make certain I understand my own posts.
                          Sorry, sack cloth and ashes for me. Again…
                          embarrassed
                          Tim Stevens
                            @timstevens64731
                            A quick note about the ruler test for height of a cutting edge: The test will only give accurate results if the bar in the chuck is running true. If the chuck is worn (like they all are) this is not usually going to be the case, so to be sure, turn a small amount off the surface of the bar in the chuck so the ruler rests against bright new metal.
                            Cheers, Tim
                            Edited By Tim Stevens on 13/03/2020 17:28:03
