Most dies have a slight lead taper, this is on the side with the size engraved on it, make sure byou have this side facing the work.
Your diestock will have 3 screws, place the die in the stock and tighten the middle one until it just starts to expand the die, then just wind the othe two in until they touch the die. You can then start threading. Turn the die one full turn forwards and half back and so on to break the chip off (not really needed with brass)
Now try a nut on the thread, if its too big slacken the middle screw & tighten the outer ones to close the die and cut again, repeat until you get a good fit.
A small chamfer on the end of the rod will help the die to start
Jason
PS you are not trying to thread 1/8″ bar by mistake ?
Edited By JasonB on 18/10/2009 21:31:00
