WF thread..
WF thread..
Home Forums Workshop Tools and Tooling WF thread..
  • #276321
    MW
      @mw27036
      I found an old tap and die with just "WF" written on it, along side the TPi and dia.
      What does it mean?
      Thanks
      Michael W
      MW
        @mw27036
        #276324
        Emgee
          @emgee
          Firm or owner's initials ?
          Emgee
          #276330
          John Stevenson 1
            @johnstevenson1
            Whitworth Form
            #276331
            Hacksaw
              @hacksaw
                 whitworth fred       if it come from London !
              I've got a 2" square die with R stamped on it … A 99 year old guy , who if still alive would be 110 gave it to me
              Said it was his fathers who worked on the railways… Railway thread ?
              Edited By Hacksaw on 07/01/2017 14:40:31
              #276335
              Brian H
                @brianh50089
                I have a number of taps and dies with WF on them and it stands for Whitworth Fine.
                #276340
                MW
                  @mw27036
                  Thanks, I tried searching for it but nothing came up.
                  Hopefully my forum thread title will  come up as a close result on a search engine to help others as well.
                  Michael W
                  Edited By Michael-w on 07/01/2017 15:52:14
                  #276341
                  John Stevenson 1
                    @johnstevenson1
                    It's definitely Whitworth Form.
                    I have some taps here 2" x 4.5 tpi, clearly marked WF and no way is 4.5 tpi classed as fine thread.
                    #276455
                    Ian S C
                      @iansc
                      2" x 4.5 is BSW, 2 x 7 is BSF, so WF Whiworth Form is my vote.
                      Ian S C
                      #276470
                      not done it yet
                        @notdoneityet
                        Perhaps the OP might have listed the diameter and pitch at the beginning? Much less obscure discussion and more sensible outcome in fewer guesses (or without any) from the members. I expect JS is correct.
                        #276478
                        MW
                          @mw27036
                          It's 1/8 x 32tpi I think.. I was satisfied with JS's answer from the start. Whitworth form, makes complete sense. Thanks for the help.
                          #276488
                          JA
                            @ja
                            The term Whitworth form suggests that there was another thread form in general use at the time or earlier.
                            JA
                            #276495
                              1/8" whit is usually 40tpi, so may not be a Whit thread but a 55degree thread so could be 1/8 x 32 ME.
                              #276504
                              MW
                                @mw27036
                                Posted by JasonB on 08/01/2017 13:19:47:
                                That sounds like I got a lucky find, so does ME have a common form with whitworth?
                                Michael W
                                #276508
                                Circlip
                                  @circlip
                                  Posted by not done it yet on 08/01/2017 12:04:05:
                                  Why make life difficult when with a bit of extra effort you can make it abso bl***y lutely impossible.
                                  Regards Ian.
                                   WhitworF
                                  Edited By Circlip on 08/01/2017 14:31:36
                                  #276510
                                  John Stevenson 1
                                    @johnstevenson1
                                    Posted by JA on 08/01/2017 12:46:15:
                                    JA
                                    Oh but there was.
                                    Every engineering concern had their own, even to the extent that one nut would only fit one bolt.
                                    Whitworth was the first to standardise the thread system and so anything marked WF denoted it was to a standard.
                                    #276698
                                    Ian S C
                                      @iansc
                                      The model engineers thread was BSEF/extra fine, there is a parallel to this in USA, the UNEF.
                                      Ian S C
                                      #276713
                                      Rick Kirkland 1
                                        @rickkirkland1
                                        Thank Goodness for the wisdom and accurate knowledge of John Stevenson. As I said in another thread on here there are too many with very little true knowledgeof anything. I sometimes wonder if John gets as angry as I do reading some of the stuff that gets posted. I also know someone who maintains that AF on any spanner next to the size stamping means American Fine. I truly despair.
                                        Edited By Rick Kirkland 1 on 09/01/2017 10:48:46
                                        #276714
                                          Posted by Michael-w on 08/01/2017 14:07:18:
                                          … so does ME have a common form with whitworth?
                                          Michael W
                                          Yes … or, to put it more correctly: the ME threads are 'Whitworth Form'
