Welding wrought iron
Home Forums Workshop Techniques Welding wrought iron
Viewing 25 posts - 1 through 25 (of 25 total)
  • #387718
    Speedy Builder5
      @speedybuilder5
      Had an interesting problem today, asked to weld up a broken bit from an iron gate. Set to with a MIG, mild steel wire and CO2 gas. It didn't go well, and the joint didn't flow very well, with much 'slag' being formed on the welding tip.
      I am assuming that I was welding wrought iron and not mild steel – The gate was probably 150 years old, definitely not cast iron. Any ideas from the team as to what I should have used ??
      BobH
      Speedy Builder5
        @speedybuilder5
        #387720
        Michael Smith 15
          @michaelsmith15
          Due to the impurities genuine wrought ca only be forge welded Mike
          #387723
          Alan Waddington 2
            @alanwaddington2
            If all else fails, braze is usually a safe bet
            #387724
            Jeff Dayman
              @jeffdayman43397
              If it is wrought iron and you can't forge weld it for any reason, bronze welding with oxy acetylene will work OK for a structural repair if the surface is cleaned well. Only issue is the weld will be yellowish brassy colour so some flat black paint would be in order to dress up the repair.
              If it's a special artefact needing proper restoration type repair I suggest taking it to a blacksmith for forge welding.
              #387745
              Ady1
                @ady1
                They cut down all the wrought iron railings in Edinburgh to help the war effort
                They sat in a pile at Carstairs Junction until 1946 when some scrappie heaved them away
                #387768
                Ian S C
                  @iansc
                  You need a forge, an anvil and a big hammer, and some sand for flux. Yes wrought iron is a bit of a beginers trap when it comes to welding.
                  Ian S C
                  #387810
                  duncan webster 1
                    @duncanwebster1
                    The Welding Institute gives different advice, and they should know what they are talking about, see **LINK**
                    #387974
                    vintage engineer
                      @vintageengineer
                      You can use Dissimilar welding rods but you need a stick welder.
                      #388002
                      Speedy Builder5
                        @speedybuilder5
                        I use MIG stainless wire and Argon on cast iron. Do you think it would have worked on wrought iron.
                        #388049
                        vintage engineer
                          @vintageengineer
                          I don't know which idiot decided it would be a good idea to cut down all the wrought iron railings for the war effort. Because they are of no good what so ever for making steel!
                          Posted by Ady1 on 26/12/2018 22:31:02:
                          #388054
                          Hopper
                            @hopper
                            Posted by vintage engineer on 29/12/2018 00:06:17:
                            Probably why they sat in a pile until after the war.
                            #388071
                            Clive Foster
                              @clivefoster55965
                              Followed Duncans link to the TWI site and was pleased to see that my usual "difficult iron" MMA, stick, welding method seems to be approved practice.
                              My Rule 1 is avoid anything taking tensile or anything beyond mild shear stresses like the plague! Usual engineering assessments of what it is and why it broke before agreeing to try. Try being the operative word. Over-engineered "if its stiff enough its strong enough" design and broke 'cos dinkle brain hit it really hard in the wrong place are usually a good start.
                              If it passes that assessment then decent grind out to give space to weld. Start by buttering on thin layers of weld metal at low current waiting for it to cool properly between layers whist peening with the chipping hammer. Take the grinder to any bits that look bad or are improperly adhered. Four to six buttering passes are usually enough to get a nice clean layer of good weld metal allowing more normal currents and larger rods to be used to finish the join. Still relatively small rods and low current in thin layers followed by peening as it cools ready for the next pass. Can take ages but it works.
                              But as TWI says wrought iron is very variable and you need to watch what's happening very carefully. I suspect you end up digging pretty much all of the slag inclusions out of the area where you want the weld to adhere. Lord knows what that does to the strength and stress resistance profile in in the joined area. Hence Rule 1.
                              Doing such repairs on old cast iron with lots of free carbon can leave you looking like a coal miner! Try to avoid architectural stuff. Or at least slap a shower tax on the price.
                              The relatively inexpensive amateur friendly rods seem to be fine for this sort of work. Probably because they are made to cope with poor technique on a goodly range of materials.
                              A good inverter welder is much better than the common inexpensive AC buzzbox for this sort of thing.
                              Best technique is to send them down the road to bother someone else!
                              Clive.
                              #388073
                              Ady1
                                @ady1
                                Lord Beaverbrooks idea
                                Edinburgh wasn't getting touched by the war (bombing) and he came up with this one as her sacrifice
                                He ended up being shoved off to Russia
                                I never knew he became a Canadian citizen before now though
                                #388079
                                Ian S C
                                  @iansc
                                  It wasn't only Edinburgh, Glasgow and Paisely lost all their iron railings too. The same thing happened here in NZ, but before WW2, then during WW2 the Japanese tried to give it all back.
                                  Ian S C
                                  #388186
                                  duncan webster 1
                                    @duncanwebster1
                                    So why can't you make steel out of it? I would have thought that as long as you can melt it the inclusions would flot to the top and you'd be left with .
                                    #388224
                                    Ady1
                                      @ady1
                                      Too many impurities and no-one knows whats in it to start with
                                      So you can't make anything reliable
                                      Some would be cast iron, some wrought iron, some god knows what
                                      Decent metal is like making a decent soup, you've got to know whats going into it to start with, nice fresh ingredients make good soup
                                      Back in the war if they could have used it it would have been gone in a flash
                                      #388225
                                      Ady1
                                        @ady1
                                        Wrought iron is tough, malleable, ductile, corrosion-resistant and easily welded
                                        From the wrought iron wiki
                                        Probably depends on the "grade" though
                                        Sounds like a suck-it-and-see material to me, every batch is different
                                        #388230
                                        vintage engineer
                                          @vintageengineer
                                          The problem is the make up, is a semi laminar construction with all sorts of crap between the layers.
                                          #388244
                                          Ian S C
                                            @iansc
                                            The problem is that wrought iron is as near to pure, carbon free iron as you can get, it's melting point is much higher than carbon steel. In the smelting process the metal never becomes liquid in the furnace (Puddling Furnace), as much slag as possible is removed, the rest gets stirred into the mix. The lumps of iron (blooms) are then forged to shape. There was a Guy Martin program on the subject, they dug up some iron ore, smelted it in a crude furnace, then made something, can't remember what.
                                            Ian S C
                                            #388252
                                            Howard Lewis
                                              @howardlewis46836
                                              Slightly off topic,
                                              ALL towns and cities lost their iron railings. Can remember seeing them being cut with Oxy Acetylene in Hereford and Wolverhampton. No doubt the words were "Don't you know there's a war on?", uttered by some bureaucrat who did not know the difference between cast iron and steel.
                                              #388385
                                              Ady1
                                                @ady1
                                                When it rusts it's like puff pastry
                                                Seems to go bad at random too, some bits rust right through into flake while two inches away on the same surface it's still as good as the day it was first painted
                                                Joint zones seem to be pretty vulnerable too, but most metals suffer from that issue
                                                #388433
                                                Ian S C
                                                  @iansc
                                                  You can find old edged tools, such as axes, and adzes with the main body of the tool made of wrought iron, with the cutting edge of steel with enough carbon to be hardenable forge welded to it. 200 years ago steel was used in a way similar to the way tungsten carbide is used today. The more the WI is hammered out, the finer the slag layers become, and the better the quality of the piece.
                                                  Ian S C
                                                  #390166
                                                  duncan webster 1
                                                    @duncanwebster1
                                                    Posted by Ady1 on 30/12/2018 09:19:36:
                                                    Spoke to a metallurgist who used to work in the steel industry. According to him you could throw any old scrap, wrought, cast whatever into a furnace as long as it had flux and you got it properly molten. The problem nowadays is 'tramp' metals, ie copper and so on that get mixed in
                                                    #390293
                                                    Ian S C
                                                      @iansc
                                                      With wrought iron there is no contamination by other metals, or grades of steel, it is the first stage from raw ore, straight out of the ground, and into the furnace. As there is virtually no carbon in the smelted iron, the temperature to melt it to liquid is very high, so the metal got to a paste, this got puddled (stirred) to bring as much as possible of the slag to the surface for removal, as the metal cooled it was bought out in lumps known as blooms, and this is what the blacksmith got to work on. I think there is a group in England who are, in a very small way making wrought iron.
                                                      Ian S C
