My current 200amp AC/DC unit cost less than £500 is single phase, came with a pedal which I don't! use, I prefer to use the slope up slope down function as a sort of manual pulse, between two preset values, it came with a not too bad Tig torch, it has adjustable auto Pulse, high frequency start, cleaning bias adjust and all manner of other settings, and you can carry it in one hand, I bought it after I borrowed a Chinese tig set from a mate whilst my much larger and far more expensive American machine was away getting repaired, to be honest I had my doubts when I first borrowed it, however I find it easier to use and it makes me a better welder, the only thing it may be less good at is duty cycle, but up until now its not been a problem, by the way I sold the American one and got enough cash to buy the new one, with enough change to buy another two, the only changes I've made to the new machine is replace the Tig torch, with a flexi head one, and fit a good quality gas lens, as it came the torch although good was unusable due to no lens and wrong cup fitted, My auto head set cost £150 10 years ago, I've been told you can get better ones for less now, I would say they are an essential item for Tig, As with a lot of things welding is a skill the more you do it the better you get, my advice would be to go on a welding course, that way your using there gas, I pay £50 cash for a refill of my full size Argon bottle, I have welded 10mm aluminium with my new welder, and repaired 22guage titanium exhaust headers, without any problems, but the wheel on the leky meter nearly takes off with 10mm ali……..
Shaun
I put some pictures of Inconel welds, done with the new machine in my new bike album.
Edited By Involute Curve on 03/01/2015 18:11:29
Edited By Involute Curve on 03/01/2015 18:36:37
