Welder wire
Welder wire
Home Forums Beginners questions Welder wire
  • #10958
    anthony brooks 3
      @anthonybrooks3
      anthony brooks 3
        @anthonybrooks3
        I have a rollof flux core steel welding wire. It has rust on it.
        Scrap or useable?
        Cheers
        #562559
        Nick Wheeler
          @nickwheeler
          How big is the reel? One of the small ones from Halfords probably isn't worth the hassle.
          If it's a big one unwind the first few coils and see if the rest is rusty.
          #562561
          Simon Williams 3
            @simonwilliams3
            As above, plus:
            How much welding do you want to do
            How rusty is it
            What damage to the wire feed tube can you put up with
            Is it rusty enough it won't feed through the copper collet in the hand set
            Even if it does, are t=you going to get an irregular contact and thus a intermittent arc?
            What class of work are you engaged in. If you're blacksmithing then it may be OK, if you are doing something structural then it's not going to fly
            #562563
            anthony brooks 3
              @anthonybrooks3
              It is a small roll. I will scrap it.
              Thanks
              #562564
              anthony brooks 3
                @anthonybrooks3
                What is used to reduce build up around the nozzle?
                #562574
                Nicholas Farr
                  @nicholasfarr14254
                  Hi Anthony, tip dip is what you what for keeping your nozzle from build up Tip Dip
                  Regards Nick.
                  #562617
                  Ebenezer Good
                    @ebenezergood76202
                    I just knock the slag off with pliers now and then as I'm working. If you have the option go with gas instead of gasless it's much nicer.
