Hi there,
Generally, inverter power supplies are more efficient than the cheap 50Hz transformer welders, so, yes, you should be able to get more weld amps for the same mains current, BUT, only a little more..maybe 10% to 15%..
The losses in the 'poor' quality laminations in the transformer core of the 50Hz welder are not that high and neither are the coil winding losses, even if the windings are aluminium, as many seem to be these days.
Ignoring the efficiency difference, and even assuming a 100% efficient inverter supply, lets look at what the 220v mains would have to provide. The welder has a high open-circuit voltage ( 50 to 70 volts), to enable the initial start of the arc. This then drops to a level required to maintain that arc, at that amperage, and that voltage varies according to the required weld current, a constant current source. Typically:
@ 60A weld current, 1.6mm welding rod ,ARC volts approx = 21volts = approx 6amps from 220V mains
@ 100A weld current, 2mm welding rod ,ARC volts approx = 26volts = approx 11amps from 220V mains
@ 150A weld current, 3mm welding rod ,ARC volts approx = 30volts = approx 20amps from 220V mains
@ 250A weld current, 4mm welding rod ,ARC volts approx = 39volts = approx 55amps from 220V mains
No free lunch, even with an inverter supply…
But you do get nice control of the arc and amps! And the machine is so small and light.
regards
Joe
