Wavy Parallels
Wavy Parallels
Home Forums Beginners questions Wavy Parallels
  • #528336
    Clay Jones
      @clayjones22389
      Hi all. Well the workshop is prepped, the WM16B is on order, forum has been scanned to an inch of its life to soak up your obvious impressive knowledge and a nice delivery of tooling has been purchased. I have bought some 8mm parallels but keep noticing Wavy Parallels. Question is are they handy and more importantly why and when would I use them and just how precision are they.
      Clay
      Clay Jones
        @clayjones22389
        #528339
        Oldiron
          @oldiron
          Hi Clay. Wavy parallels are very handy for use with thin work pieces as they will deform within reason to the width needed.
          regards
          #528343
          Clay Jones
            @clayjones22389
            Many thanks.
            #528344
            Clay Jones
              @clayjones22389
              Many thanks.
              #528348
              Rod Renshaw
                @rodrenshaw28584
                Hi Clay
                In addition to the use described above by Oldiron, it is useful sometimes to use accurate "normal" parallels to rest the work on, and use slightly lower wavy parallels between the normal parallels to keep the normal parallels from toppling over.
                Rod
                #528350
                Clay Jones
                  @clayjones22389
                  Just what I find so helpful about this forum, simple but clever tips like that, thanks Rod.
                  #528353
                  Oldiron
                    @oldiron
                    Posted by Rod Renshaw on 18/02/2021 18:25:54:
                    Hi Clay
                    Rod
                    In the absence of wavy parallels a piece of foam rubber makes a good substitute for that purpose.
                    regards
                    #528385
                    Paul Lousick
                      @paullousick59116
                      "Band-it" strapping is very useful in the workshop. Cut into small lengths as shims to raise the height of lathe tools and bent into a U-shape as a spring between the parallels to keep them pressed against the vice jaws.
                      Paul
                      #528387
                      Clive Foster
                        @clivefoster55965
                        If you don't have Band-it strapping sections of worn out or broken hacksaw blade with the teeth ground off are also make good shims.
                        Hardboard strip against one vice jaw is great for improving grip on something a bit rough or slightly out of parallel. It squidges well enough to tahe up the diffrences but still firm enough for a good grip. Just remember to measure from the other jaw!
