A bit worrying that among the butchers, carpenters and general mechanics, dentists would also find invaluable, an off-hand grinder with no tool-rest and supported apparently only by the turbine's attachment to the tap….
The Bray patent application is interesting but to succeed he would have needed prove novelty of design, not of "improvement".
His is a simple Pelton turbine but what would appear to be his claim is fundamentally flawed.
The true Pelton "bucket" (yes, it is called that) is a twin component like a pair of spoons side-by side. The central wall is sharp, and exactly on the centre-line of the single nozzle. There may be more than one nozzle per turbine, but only one per bucket.
The result is that the water divides into two equal streams flowing down their own sides of the wall to impinge on the bottom of the bucket – impulse action.
The spoon shape of the bucket then reverses each stream by somewhere around 150º or so, making it leave the bucket somewhat to the side of the wheel, and possibly giving a reaction component.
This smooth reversal extracts the bulk of the jet's potential energy.
The bucket usually also has a semicircular notch in its rim. I take it that this eases its movement into the jet at the best angle.
Bray's provision of two nozzles means the water will hit the bucket close to the bottom of the "spoon", making the reversal less efficient. Further, some of the water would rebound up the central wall, so the two jets would interfere with each other.
He would have been better, perhaps, using two single nozzles on opposite sides, but I doubt he could have patented that. Many large industrial turbines were built with multiple nozzles, each with its own valve, for speed control.
I have seen a small grain-mill driven by two very simple reaction-turbines. Located in the Pyrennean foothills, it was clearly preserved and open to visitors, but closed when we saw it. Even so, I managed to paddle into the large, arched tail-race to inspect the two turbines, of open construction.
Bright shiny stainless-steel bolts contrasted with the dark cast and wrought irons, showing recent repairs.
The runner resembled a simple extractor-fan. .An iron ring maybe 150 mm deep (this is France!) by 500mm diameter, having four, rigid, "spoke" vanes inclined at 45º to the plane of the wheel. The wheels are on vertical shafts rising through the floor above, perhaps driving the stones directly rather than through gears.
The water simply falls onto the turbines from curved elbows protruding from the wall, with their sluices or valves presumably in the mill, built basically on the dam. The head (from memory) would be about 3 or 4 metres.
I spotted a large salamander in the shallow tail-race water.
