Water gauge problems
Home Forums Locomotives Water gauge problems
  • #138592
    David Machin
      @davidmachin95465
      I have twice tried to add another post , without success.
      Here goes again: First, thanks for your latest posts. I will try out your suggestions ASAP, but I expect this will now be after Christmas, and when some dry weather occurs! Julian, do you think I need to have more Sodium Hydroxide boiler cleaning attempts?
      julian atkins
        @julianatkins58923
        hi dave,
        difficult to know without examining the loco myself. one dose should be enough. the only sure fire method is to add some hot water to the boiler, jiggle it about, and then unscrew the whole of the blowdown fitting in a good light and catch what comes out (and inspect same) and then inspect what crud may be around the blowdown boiler bush on the inside. i would try the regulator gland test first, as best not to disturb boiler fittings if at all possible.
        cheers,
        julian
        #139025
        David Machin
          @davidmachin95465
          Thanks Julian.
          When I have some suitable weather, I will have do as you suggest. That may be some time if recent forecasts atre to be believed……
          Thanks again,
          David Machin
            @davidmachin95465
            Success at last!
            I have sleeved the water gauge feed 'tubes' to the boiler down to match the glass bore, which I know is contrary to what you said, Julian, but it has done the job.
            I had a steam up this morning, which was completely successful, the level being controllable throughout, with no problems at all.
            So my thanks to you all for your kindly contributions, particularly about cleaning the boiler with the drain cleaner (sodium hydroxide) from Wilco.
            Happy steaming,
            Dave.
            #140624
            julian atkins
              @julianatkins58923
              hi dave,
              glad to hear that the problem is solved, though not quite sure why!
              i didnt state that the passageways must be bigger than the bore of the glass only that the bottom fitting shouldnt be less and the top passageway can be a bit smaller than the bottom.
              hope you enjoy lots of successful steam ups from now on!
              cheers,
              julian
            Home Forums Locomotives Topics
